My controller chassis houses my Gecko's, Bob Campbell breakout board, and solid state relays and all is grounded to earth ground from my 110ac line. The power supply however is in another chassis and the output is isolated from the imput, therefore when I connect the ground from the power supply to the Gecko's (term 1) it will not be connected to earth ground from the 110ac line. Will this cause a problem?? |
| I really want to power up my controller this weekend, and don't want to see a puff of smoke!!! I connected the (-) from the power supply to (term 1) of my Gecko's. I also connected the (-) from the power supply to my earth ground from the ac line. Please! Please! can anyone see a possible problem with this! Thanks Chas |
| Generally it is desirable to have all the power supply commons at ground potential and if the power supplies are all initially isolated it is considered safe to make them common ground, a test to see if commoning up will cause any significant problems is to do a test to see if doing so will cause a large leakage current to flow, measure the voltage both DC and AC from the supply common you wish to ground and the actual ground, you may see a voltage with a sensitive meter due to natural leakage, which is normal, while the meter is connected place a 100ohm resistor across the meter leads an see of any leakage voltage collapses, if it does, then you should be ok to common up. Al
![]() Ken
__________________ Kenneth Lerman 55 Main Street Newtown, CT 06470 |
Actually, only 1 amp would flow if the difference was 110vac, but you would need a high wattage resistor to prevent vaporization Al
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 04-15-2005 at 04:30 PM. |
| Good earth ground, what is your definition? | gar | General Electronics Discussion | 29 | 06-15-2005 09:22 PM |
| Motor supply ground vs Logic ground? | Gashmore | General Electronics Discussion | 11 | 06-07-2005 05:21 PM |
| Power Supply Question | BobLWeiss | Stepper Motors and Drives | 13 | 04-17-2005 02:27 PM |
| FNG Power Supply Question | SteinAir | DIY-CNC Router Table Machines | 0 | 12-31-2004 09:31 PM |
| i got a power supply question | ljoe1969 | General Electronics Discussion | 21 | 01-11-2004 11:19 PM |
