Results 1 to 10 of 10
Thread: How much motor Torque(oz) does Gecko G210 7A ?
    Feb 2005
    Indonesia
    Question How much motor Torque(oz) does Gecko G210 7A ?
    How much torque does step motor available for 7A ?
    Just wondering how big(oz) does 7A step motor which is available in the market ?
    any sample ? url ? just want to know how much that motor cost.
    I'm trying to compare using Servo motor, how much I can save.
    regards
    rud
    Mar 2003
    Shelby Twp, MI....USA
    You can get 1000 oz-in motors rated ~6a for about $300 from Oriental Motor or Sanyo Denki. 2000 oz from Sanyo Denki for about $600.
    You can get 1300 oz motors for $195 from here http://www.seanet.com/~dmauch/Products2.htm
    Feb 2005
    Indonesia
    thanks,
    i wonder how much table weight can be move with 1500oz ? 500pounds ?
    rud
    Gold Member
    Jun 2003
    Calico, wouldnt it be a better idea overall to go with servos for that size machine?
    tormach.com has some larger steppers
    homeshopcnc.com also has some I think
    Jon
    Feb 2005
    Indonesia
    Jon, well the cost is the problem if I go with servo,
    my question is... does stepper can handle that ?
    what's the problem I might see if I go with stepper ?
    rud
    Registered Evodyne's Avatar
    Dec 2004
    Look at Rick Lalonde's site at http://www.homeshopcnc.com. His 1200 oz/in Model # RHT34-1200 runs $155. I did notice they are temporarily out of stock right now.
    Feb 2005
    Indonesia
    yes outta stock, but ...
    can somebody give me a figure....
    what can 1200oz stepper motor can do ?
    can it cut metal CNC mill ? do they using it for industrial CNC Mill ?
    what about the speed ? i'm sure it can cut the wood CNC Mill easyly, is it ?
    wow that 1200oz is cheap, if it's real 1200oz. I might get those if that thing can cut wood CNC Mill with 1meter Xaxis by 2meter Yaxis and 50cmZ axis deep.(all travel sizes)
    can 1200oz do that ?
    rud
    Dec 2004
    Calico,
    O.K.-a good place to start is to to look at Roton's site for ballscrews and such. Find their "Useful Formulas" section in the resources area.
    The first formula given calculates the torque needed for a given screw to generate a given linear force. Note that units are imperial, not metric.
    If I put in a load, i.e. 1000 lbf, and a screw lead, say 1 in/rev, and an efficiency of 100%, the calculator says I need 159.15 in-lbs of torque.
    But 16 oz = 1 lb, so 159.15 in-lbs = 16 x 159.15 = 2546.4 in-oz!
    Wow! That's a hefty motor. But in reality the screws can be purchased with different pitches (reduction ratios). Also their efficiency is never 100%.
    So say I now use a real-world screw: 5 turns per inch, efficiency of about 90% (ball screw-lead screws are much less!).
    Now the calculator says I need 35.37 in-lbs or 564.92 in-oz. This for a 1000 lbs of thrust.
    With a further toothed belt reduction of 3:1 ahead of the screw you would be looking at 188 oz-in needed for that same 1000 lbf.
    But beware: this doesn't mean you need a smaller motor! A stepper will generate its greatest torque (holding torque) when it's NOT moving. From there torque drops off with speed. So a 1200 oz-in motor will only generate varying portions of that at higher speeds. Ideally you would get a set of curves from the manufacturer showing torque vs. speed, etc.
    See the Stepping Motor Basics White Paper at www.geckodrive.com for a solid introduction to steppers.
    Hope this helps a little!
    Feb 2005
    Indonesia
    Evodyne,
    sorry for late reply.
    yessss it helps alot, not a little.
    thank you again.
    regards
    ruddy
    May 2005
    Motor Stepper 7a
    [QUOTE=Calico]How much torque does step motor available for 7A ?
    regards
    rud[/QUOT Go to ---- Bobcampbelldesign.com
    1. Replies: 31
      Last Post: 03-23-2005, 11:04 AM
    2. Gecko Drive sticker competition is now here
      By ynneb in forum Gecko Drives
      Last Post: 03-15-2005, 12:02 AM
    3. Gecko vs Rutex
      By samualt in forum Gecko Drives
      Last Post: 10-21-2004, 02:48 AM
    4. Servos or Steppers..... and other gecko related questions
      By UKRobotics in forum Gecko Drives
      Last Post: 04-19-2004, 03:14 PM
    5. To Gecko, or not to Gecko...that is the question!
      Last Post: 09-22-2003, 09:42 PM
