Old 01-17-2010, 10:06 AM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question Gremlin or Normal?
I’m down to the last go round of checking everything before I get brave enough to power up and I found something that brought everything to a screeching halt.
I panic when it comes to the electronics as I fried 3 Xylotex driver cards because of a misunderstanding in wiring on the first go round on my first machine. (they are still in my junk box) I was saved by Probotix and their EXCELLENT wiring diagrams (in full color) that even a newbie can follow.
My electrical parts consist of CandCNC UBOB Kit and Gecko G251 driver cards
I was turning the X axis screw by hand and I notice every time I turned it the red LED’s on all 4 (X, Y, Z and A) of the G521’s would light up then dim off. Naturally there isn’t any power applied to any part of the control box.
I kind of would expect the X Driver card to light up because the stepper acts like a generator when it is rotated, but why all axis.
Hager
Old 01-17-2010, 04:13 PM
joshendy is on a distinguished road
I imagine thats because the power generated goes back through the mosfets of a single drive and goes into the dc line which powers each of the 4 axis'. Therefore powering each of the drives.
If you put a multimeter on the dc input to the G540 you'd see a small amount of voltage when you turn any one of the motors.
Old 01-17-2010, 10:42 PM
Mr.Chips's Avatar
Gold Member
Thanks Joshendy, I was hoping it was not an issue.
And welcome to the forum.
Hager
Old 01-18-2010, 09:17 AM
Gold Member
Mariss Freimanis is on a distinguished road
It's not an issue. The motor being back-driven becomes an alternator, its AC voltage gets full-wave rectified by the attached drive and the resulting DC voltage appears on the power supply bus. This voltage begins to light-up the other drives and loads the back-driven motor, limiting this effect to a safe voltage.
Mariss
Old 01-18-2010, 10:06 PM
mlabruyere's Avatar
mlabruyere is on a distinguished road
Yup....as the others have said this is normal. The motors act as generators when you turn them by hand.
I wonder if putting a diode in line on the stepper wires will prevent this?
Old 01-19-2010, 09:30 AM
Gold Member
Don't put any parts of any kind on the motor leads! Putting a diode across the winding will destroy a G251.
Mariss
Old 01-19-2010, 10:08 AM
Mr.Chips's Avatar
Gold Member
BOY, that is good to know!
Old 01-19-2010, 10:13 AM
mlabruyere's Avatar
Mariss
Wow....really. Why is that?
Name:	1-19-2010 8-07-36 AM.jpg‎
Old 01-19-2010, 03:59 PM
yorkrose is on a distinguished road
Even if the G251 was made of Kryptonite this would not work, for at least two reasons. The most basic reason is that the current must flow in a circuit. The diodes shown would never allow any significant current flow. Also, in most cases bi-directional operation is needed. The current flow needs to be supported in both directions on each wire.
Gene
Old 01-19-2010, 07:12 PM
mlabruyere's Avatar
Gene
...................................................................................................................................................................................................ME
Yeah...not thinking....the coil has to have a flow of current....duh. And it has to be able to flow in either direction to boot....well frick.
Like I said...if it would have worked they would have built them this way.....
Problem- Continuing 4th axis and electrical gremlin woes ralph@nes Haas Mills 17 11-27-2008 08:55 AM
Problem- This is NOT a normal noise Dancy Fanuc 11 05-24-2008 04:26 PM
Way stains Normal? Dan S Mini Lathe 1 09-27-2006 03:50 AM
How much vibration is normal? kombayotch Bridgeport and Hardinge Mills 1 02-17-2006 05:55 PM
Normal stepper operation? LeeWay Stepper Motors and Drives 5 03-11-2005 07:33 PM
