Old 04-04-2005, 02:36 PM
CaptnVideo is on a distinguished road
Mitutoyo DRO for CNC
Has anyone tried adapting a Mitutoyo DRO for use with CNC milling machine.
I would like to use the linear scales I already have mounted on my machine.
Talk about zero backlash.
Found a pdf file on Mitutoyo site on scales, will study it and check against my hardware. I was hoping I would be able to plug directly into the recorder outputs.
Old 04-04-2005, 02:48 PM
Al_The_Man's Avatar
Mitotoya usually can be adapted as the ones I have used have had +5v differential output.
You may have to reverse engineer the channels, IIRC the + and common is red & black so just power it up and check with a meter or scope.
Al
Old 04-04-2005, 05:21 PM
Thanks Al, will do, would you happen to know how many pulses per inch they are?
Old 04-04-2005, 05:22 PM
Al_The_Man's Avatar
The ones I used were 2µm and 5µm
Al
Old 04-04-2005, 06:08 PM
As I recall, I think I bought the less expensive ones which would be the 5s, so about .0002in, way better resolution than I need. Thanks Al
Old 04-08-2005, 12:03 PM
Hi Al. I got some responses in the electronics section, and a note back from Gecko that the motors will oscillate the amount of the backlash in the machine. Have you run into this problem?
Mutilated mouse DRO (using Microsoft PS2 Mice) wcarrothers General Electronics Discussion 6 03-30-2009 11:37 AM
Cheap DRO Design playinsteel General Electronics Discussion 3 07-21-2005 10:54 PM
DRO - Metric or Inch DJ Morrow General Electronics Discussion 2 11-15-2004 02:06 PM
if cnc..do I need DRO?? camfambmw5 General Metal Working Machines 7 03-25-2004 11:07 AM
Heidenhain DRO advice kong General Metal Working Machines 4 02-29-2004 02:44 PM
