Trying to find an add-on card that works with the G540 charge pump circuit. When the pump is disabled everything else seems to be fine, I can jog the motors and there appears to be no other issues, but no matter what I can't get the Charge Pump to enable without faulting. At this point I can only assume it's the PCI parallel card. Pertinent info: - G540 in pre-wired Keling box - Mach3 - DB25 straight thru cable - EPP compatible PCI card with latest mfg driver file (Rosewill RC-304)(Most likely not 100% EPP according to the FAQ's on the Rosewill site) - Port address is correct in Mach3 - 540B xml file from Gecko (Charge Pump on port #1, pin 16) - "Use Watchdogs" and "Charge Pump on in e-stop" are both checked in the General Configuration table. - I don't have an option for EPP in the Device Manager anywhere. - Win XP So, does anyone out there have a PCI add-on parallel card that can get the charge pump to work with a G540 and Mach3? If so, what card and was EPP an option in Device Manager or maybe a seperate utility? Any help or advise appreciated. Regards, Frank Last edited by Jr's Farm; 12-22-2009 at 02:03 AM. Reason: More specific wording to help eliminate confusion. |
| Frank, Siig works when all others fail. http://www.siig.com/ViewProduct.aspx?pn=JJ-P00112-S6 Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Frank, We have used Siig on several customers machines, I don't recall the device manager configuration. The Moschip NM9715 "Rosewill RC-304" has been discontinued for almost three years due to compatibility issues. Moschip replaced the NM9715 with the NM9815 "9800 series" . Sorry I could not give more detailed info on the Siig. Jeff...
| You don't set EPP in device manager you set it in bios. Dan Mauch
| I think you might have missed the fact about the PCI parallel add on card. The BIOS only works for the motherboard integrated parallel circuit, which I unfortunately don't have. So I'm looking for a way to utilize EPP on a PCI add on card. As I undertand it, on compatible cards it may be an option in Device Manager. Frank |
__________________ ------------------------------------------------- Homann Designs - http://www.homanndesigns.com |
I edited and reworded the original post to help eliminate confusion. - "Use Watchdogs" and "Charge Pump on in e-stop" are both checked in the General Configuration table. Regards, Frank |
| Frank, You and I definitely are having the same problem. See my post on green light... as I have added more info. I just ordered a Lava PCI card. We'll see if that one works. It uses a different chip, so maybe I'll get lucky this time. I'll keep you informed. Ron |
#10
| ronncat, Quoting you from your "Need Help! G540 Green Light..Go or no go? " thread here, as the info form Mariss might help others understand the shortcomings of the PCI parallel card issue. Great info!
And of course your followup with the Moschip info pretty much states the same that I found at Rosewill (use's Moschip 9815), in that you can only change the port mode in DOS or Windows NT. I'm not sure how they can say that the card is compatible with all the software they say, when clearly it's not. Oh well. Still looking. Frank |
#11
Hi- I'm having the same problem. My onboard parallel port doesn't support EPP in bios and I've tried MosChip and SIIG cards. Did anyone find a card that works? Has anyone tried to solve this with the CNC4PC C26 - Output Buffer Board? Thanks, Kevin |
#12
The problem with MOSCHIP (and possibly other) interfaces driving the G540 signals other than step and direction results from the outputs being "open drain" unless the interface is set to EPP mode which cause the chip to use regular totem-pole TTL style output drive. The G540 inputs are just a current limiting resistor feeding the positive side of an LED inside of an optocoupler. The negative side of the LED is returned to ground. This means that the parallel port signal must be able to source enough current to turn on the LED. The open drain style outputs cannot source current and rely on whatever pull-up resistor the board manufacturer provides as the source of current when the signal is supposed to be high. This resistor is often a large enough resistance value to limit the current to a value below the response current threshold of the optocoupler. When the port is set to EPP mode, the chip actively drives the signal high and the problem goes away. I do not know if any parallel port chips will behave differently, so the solution is to find a board that provides you with a way to set EPP mode without assistance from the BIOS. This will probably take the form of a utility or driver supplied with the board. Some breakout boards, including PMDX products, will buffer the signal with a CMOS gate instead of directly driving an optocoupler. This reduces the probability of the problem but may not always eliminate it. Some PMDX boards have a 10K ohm pull DOWN resistor to assure that an input that is not connected assumes the LOW state. If the pull up resistor on the open drain outputs of the parallel port are greater than 5K ohms, operation may not be reliable. The original IBM parallel ports used 1K ohms and most but not all vendors followed this tradition. Regards, Steve Stallings www.PMDX.com |
| Charge Pump | cadmonkey | LinuxCNC (formerly EMC2) | 8 | 04-06-2010 01:19 AM |
| charge pump | michaelf | Benchtop Machines | 23 | 10-25-2009 05:55 PM |
| G540 charge-pump not pumping | aystarik | Gecko Drives | 2 | 05-14-2009 02:38 PM |
| G540 Tempremental charge pump detector | David Campbell | Gecko Drives | 1 | 03-20-2009 07:18 AM |
| Charge pump | mlaws1172 | Screen Layouts, Post Processors & Misc | 0 | 01-03-2006 10:46 PM |
