Hi, I just turned on my first G203v drive with motor connected Green LED on, but no motor spinning. I have LED's on BB and can see the signal being sent. Motor was not locking either but felt stiffer then normal. I powered down drive and disconnected motor from lead screw and motor is still stiff to turn. ( more than normal ) Can somebody check my motor phases connections are correct as this is where I think I've gone wrong ? Text from Geckos data sheet TERMINAL 3 Motor Phase A Connect one end of your “Phase A” motor winding here. TERMINAL 4 Motor Phase /A Connect the other end of your “Phase A” motor winding here. TERMINAL 5 Motor Phase B Connect one end of your “Phase B” motor winding here. TERMINAL 6 Motor Phase /B Connect the other end of your “Phase B” motor winding here. I've uploaded PDF off motor data sheet My connections are as follows: Red/Yellow Phase A TERMINAL 3 Blue/Black Phase A TERMINAL 4 White/Orange Phase B TERMINAL 5 Brown/Green Phase B TERMINAL 6 Any information on this matter would be gratefully received Dale Gribble |
| For further reference I found the correct connections on Gecko support page, motor is now spinning nicely. I upload image from the PDF. Regards Dale Gribble Ps I saved the wrong image it should of shown connected in parrallel. See Jeff modifed image for reference. Set resisitor to 120k @ 5a to leave a small safety margin. Thanks for the reply Last edited by Dale gribble; 12-17-2009 at 11:21 AM. |
| Dale, You have it wired incorrectly. See attached image for correct wiring diagram. Current set resistor should be 282K "6A". Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| You should have Red-Term3 Black-Term4 tie bue and yellow together White-Term5 Green-Term6 Tie Orange and Brown Together
| yep, I screwed up and gave you series.
| Newbie- hel with DC motor drive connections | leandrot | General Electronics Discussion | 7 | 06-04-2010 02:15 PM |
| Stepper motor connections | muddobber76 | Vertical Mill, Lathe Project Log | 8 | 11-17-2009 09:06 AM |
| Stepper motor connections | muddobber76 | Controller & Computer Solutions | 1 | 10-12-2009 12:18 PM |
| Newbie- Basic cable connections | pietervanstee | General Electronics Discussion | 4 | 03-12-2009 04:35 PM |
| Yaskawa Minertia motor connections | belli | Servo Motors and Drives | 7 | 01-28-2007 10:35 PM |
