Old 12-13-2009, 04:10 PM
Propaganda's Avatar
Propaganda is on a distinguished road
Noisey motors when idle. Normal?
Hi Everybody.
I am bench testing my first setup using Keling 381oz 4wire steppers and a G540. The PSU is a 48v 7.3A switching power supply. When idle the steppers make quite a wide spectrum of different noises. Sometimes I hear a high pitch squeal (chirping) other times I hear a low frequency hum. They also like to vibrate slightly. There is no change if the G540 is plugged into the computer or not.
Is this normal?
Thanks.
Old 12-13-2009, 06:12 PM
beliefdrive is on a distinguished road
Check power capacitor . i 'm think you'r mistake conect, it need less than 30cm with dirver
Old 12-17-2009, 11:23 AM
Propaganda's Avatar
Well, there is no power capacitor per say, it's a switching PSU. The PSU is a MeanWell authentic. However the power leads were 31cm and I lowered them down to 20cm for good measure which produced no difference.
After getting information from another thread it appears that a little motor noise at idle is nothing to be concerned about, considering the motors still are energized at 70% power, but I am still not 100% sure.
"The whole world must learn of our peaceful ways... by force!" - Bender Bending Rodríguez
Old 12-17-2009, 06:22 PM
if you use switching psu, you need add diode to protec PSU.
Old 12-17-2009, 06:27 PM
ger21's Avatar
Have you adjusted the Trimpots?
ADJUSTING THE TRIMPOT
This trimpot adjusts the motor for the smoothest possible low-speed operation. Set the motor speed to about 1/4 revolution per second, and then turn the trimpot until a distinct null is noted in the motor’s vibration. This will result in the most even microstep placement for a given motor and power supply voltage.
Old 12-17-2009, 10:13 PM
TOTALLYRC is on a distinguished road
If it is an early version there was a minor problem in that there was some current running around and making the motors hiss.
This applies to the early G250/251 and I think the early G540 but I am not certain. The fix is simple but I don't remember where I saw this and I have yet to do it to my machine but IIRC it was just a resistor to be added by the user.
The newer ones have had the problem fixed. Mariss has a nice write up of it somewhere. Sorry I don't have all the info but the mind is in Jello mode tonight.
Mike
Old 12-18-2009, 06:12 AM
Chris D's Avatar
Chris D is on a distinguished road
You add 1k (I think that is the correct value) resistors to each signal ground wire. This minimizes the hiss.
Chris
Old 12-18-2009, 07:13 AM
ger21's Avatar
Took a while, but i found the info.
http://www.cnczone.com/forums/showpo...44&postcount=2
Old 12-18-2009, 01:51 PM
Propaganda's Avatar
Thanks for the information, I will try the posted suggestions in a few days. ATM, my equipment is packed up because I am moving out of state.
Idle machines MTSS Service Mazak, Mitsubishi, Mazatrol 0 09-08-2009 12:33 PM
Idle Spindles myouden Employment Opportunity 0 10-23-2008 08:59 AM
Super X1 Y axis noisey in one patch bruce_miranda Benchtop Machines 5 10-12-2008 05:38 PM
Need Help!- Random Pulses to Motors when Idle offthewall Stepper Motors and Drives 7 07-16-2008 10:07 PM
Motor screams and gets hot while idle methuso Hobbycnc (Products) 1 05-14-2008 12:52 AM
