Old 12-10-2009, 03:06 PM
Quazar's Avatar
Quazar is on a distinguished road
Question Silly G540 question: Unused output...
My initial CNC conversion will only need 3 axes, though I expect to add a 4th axis (rotary table) later. In the mean time the 4th driver on my G540 will go unused.
I will be covering the connector to protect it from dust/debris, but I just thought I'd ask if there is any reason to give it a 0Ω current-set resistor (to set the drive current to 0A)? Since nothing I've seen says this necessary, I'm guessing I should just leave the current resistor as an open circuit.
It would be great if the instructions specifically addressed what to (not) do with any unused outputs.
Cheers,
- Dean
Old 03-13-2010, 10:12 AM
Fastest1 is on a distinguished road
It is fine to do nothing with that output or any other 1. Just dont unplug any of them under power!
G540 VFD output floating ? Tesla_Cubed Gecko Drives 4 08-21-2009 12:58 AM
G540 Output Help finishlinewrx Gecko Drives 5 07-10-2009 12:39 PM
Need Help!- Output command for g540 DanOSB Gecko Drives 3 02-19-2009 09:06 PM
Newbie- Probably a silly question... cNcCharlie WoodWorking 6 07-01-2008 03:19 PM
Newbie- Silly Question Smitty911 CamBam 5 02-11-2008 03:30 AM
