Old 12-06-2009, 09:26 PM
mlabruyere's Avatar
mlabruyere is on a distinguished road
Mach3/Gecko G540 setup questions
Hi Everyone,
I have some setup questions....as a total noob....
I've got the Rev3 G540 and the latest stable Mach 3 installed. I used the XML file supplied.
When I hit Page up/down nothing happens even though I have a stepper plugged into the ZAxis port on the unit. If I hit right or left arrow the stepper moves but it moves in only one direction no matter the key hit.
No other axis will take any commands.....
There are no faults on the G540 or in Mach 3.
Could there be a problem with my Parallel cable? I double checked the motor pins for step and direction and they are as stated in the G540 manual.
Any help would be great!
Old 12-13-2009, 12:13 AM
mlabruyere's Avatar
Anybody out there that can help?
Old 12-13-2009, 12:41 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Mlabruyere,
There is a good chance you are using a null cable "laplink" by mistake.
You need a straight through cable.
Check it end to end with a VOM.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 12-13-2009, 11:26 AM
mlabruyere's Avatar
Thanks Jeff, I think you are right. I have another cable but it's male female....so I tried to make a gender changer. This cable was used on my easy-cnc machine so I know it's a straight through. The gender changer I made didn't work....crud.
I ordered a real gender changer (Belken). Should have it tomorrow. This will take the cable out of the equation.
Matthew
Old 12-13-2009, 12:26 PM
jalessi's Avatar
Post
Matthew,
Fry's is not that far away,
http://www.frys.com/isp/sanmarcos.html
Please keep me posted on your progress.
Jeff...
Old 12-13-2009, 01:39 PM
BTA PLASMA's Avatar
BTA PLASMA is on a distinguished road
-edit...error
Now featuring Plasmaland online
Old 12-13-2009, 11:41 PM
mlabruyere's Avatar
PROBLEM SOLVED
OK.....I got a new straight through cable (male male) and a gender changer for my other cable.
I used the gender changer on my cable I knew to be good and all the axis started to work except the "Y". The "Y" axis would stall and move in one direction then suddenly change direction without a new input.
I then tried the new cable and again everything but the "Y" worked.....frick.
So eliminated the cable as the problem. Software is setup correct......
Opened the DB9 housing and looky there....a solder joint failed.
Soldered the wire back and everything works!
Old 12-14-2009, 04:05 AM
jalessi's Avatar
Thumbs up
Matthew,
Happy to hear you are on back on track.
Jeff...
Need Help!- Gecko G540 rotger Servo Motors and Drives 0 06-02-2009 12:43 PM
gecko g540 Teyber12 Benchtop Machines 3 05-31-2009 02:23 PM
NO movement, Any suggestions for my gecko 201 and Mach3 setup? journeyonline Machines running Mach Software 1 11-15-2007 03:45 PM
Mach3 and servo motors Setup Questions!! happytriger2000 Servo Motors and Drives 3 08-31-2007 11:59 PM
More Mach3 Setup Questions bill south Mach Mill 2 05-08-2006 10:10 AM
