Hi all! I'm wiring up a small machine for engraving/pcb milling. I have x and y axis working, but z axis, which has a smaller servo motor, just spins endlessly. No fault led or anything. Using HEDS 5540 encoders, wired up with pull-up's and capacitor between Vcc and ground. I had this motor working while bench testing, but now I just can't seem to make it work... Any help welcome! /Pär |
| Just one question though, shouldn't it fault pretty quickly rather than run continuously if the following error is getting bigger and bigger? FWIW, here are my debugging notes: http://www.cnccookbook.com/CCCNCDebug.htm I would really want to make sure the drive isn't getting a step pulse that commands the motor to move. That link I give tells how to use your multimeter to see whether you're getting step pulses. Cheers, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
| Thanks Bill. I had tried that, and to swap the encoder A & B leads.
/Pär |
| Are you using an external 5v supply, or the supply in the gecko? I had your exact sypmtoms using an external supply because I didn't have the neut. of the external supply connected to the encoder neut on the gecko. Aslo, I don't know your encoder, but make sure it doesn't pull more current than then gecko (if you are not using an external PS) can handle, 100mA is it? |
| New Gecko G320X startup problems.... | pete from TN | Gecko Drives | 14 | 01-18-2010 11:11 AM |
| Differential encoder e5 with the g320x | dgalaxy | Gecko Drives | 2 | 08-28-2009 03:53 PM |
| G320X Released and Customer Appreciation Sale | CoAMarcus | Gecko Drives | 13 | 08-19-2009 10:16 PM |
| G320X First Revision Manual | CoAMarcus | Gecko Drives | 0 | 08-05-2009 06:35 PM |
| drive spins, shaft doesn't;also mach 3 question | Ed_R | Xylotex | 33 | 12-09-2006 10:30 PM |
