When I was tested all components (NEMA 23 servo, g320 gecko drive, using encoder AMT 102, with C10 break out board and using a power suply KL 600 48). I was able to move the servo correctly through Mach 3.
Now that I moved everything to a metal box I connected ground and all negarives to ground as well. Now the servos are not working, I was getting the servos to just to spin in one direction not even sending a signal from Mach 3. I disconnected ground completely and now I am getting a different fault. The servo moves to one side and then to opposite direction, I tried to tune the servo by using Limit, gain , etc. But I was not successful. The servo gets hot, and I send signals from Mach 3 and the servos do not get it.
C10 Breakout board, power supply, and gecko drives are attached to the same metal box. Should I separate all these three devices from the metal?
Please let me know what I should do to make my first
cnc to work.
Thanks in advance for your help.
DVR
