Old 11-03-2009, 02:07 AM
Nzoldun is on a distinguished road
G540 and SmoothStepper
Has anyone run a g540 with smooth stepper under Mach3?
I have the two connected up and they appear to be 'lighting up' OK, but the RESET button on the screen won't work and if 'clicked' too often the computer freezes and I have to reboot.
Old 11-03-2009, 04:52 PM
Jeff-Birt's Avatar
Jeff-Birt is on a distinguished road
They work great together. If you click the 'Reset' button or 'Feedhold' button too fast many external motion control devices will have a fit. I'm sure that will improve in the future. These buttons send specific signals to an external device if you press them really fast over and over the external device does not have enough time to process the first command and report back to Mach before the second one arrives. You only need to press 'Reset' or 'Feed Hold' once.
If your G540 is not coming out of Estop mode it is because you do not have Mach configured correctly and/or you did not install the SS driver and plug-in. Go get the G540b.xml from Geckos site and save it in your Mach directory. It has ALL the settings for the G540 all ready done, but NOT for use with the SmoothStepper. To use the SmoothStepper with that profile start up Mach with MachLoader and select the G540B profile. When Mach starts fo to the second menu over and at the bottom of the list will be 'Reset Dev Sel...', click on that, click OK on the dialog box that pops up and then close down Mach and Restart it. When Mach restarts you'll get the licensing screen and then a Screen that says 'External Motion Controller found', select the SmoothStepper from the list and check the do not ask me again box. Now the SmoothStepper is set up to be your motion control device.
Jeff Birt
Old 07-31-2010, 11:22 AM
jefftomerlin is on a distinguished road
I have tried the above suggestions, but I am still not up and running.
there is a G540 XML file and a smooth stepper XML file, which one do I load first?
G540 and Smoothstepper escott76 Benchtop Machines 28 08-28-2009 02:24 PM
Dyna 2400 and SmoothStepper Jeff-Birt Benchtop Machines 0 04-17-2009 04:03 PM
Anyone tried a Smoothstepper? Ranscon General Electronics Discussion 3 03-07-2009 12:37 PM
Need Help!- SmoothStepper and Mach3 setup jeffmorris Mach Software (ArtSoft software) 0 09-02-2008 03:09 PM
Just IN- SmoothStepper Now available in Australia. phomann Product Announcements & Manufacturer News 2 06-12-2008 08:24 PM
