I just received my G540 by FedEx. Very exciting. I've had my steppers for months and finally my Sherline mill conversion is on the move again. The motors I bought on eBay the specs are as follows: Technical Specifications SOC Part No.: SM3016B Frame Size: NEMA23 Step Angle: 1.8 degree Voltage: 3.0V Current: 3.0 A/phase Resistance: 1.0 Ohm/phase Inductance: 1.6 mH/phase Holding torque: 13.5 Kg-cm 183oz-in Rotor inertia: 480 g-cm2 Detent torque: 0.68 kg-cm Number of wire leads: 6 Weight: 2.20 lb (1.0 kg) Length: 2.99” (76mm) Shaft: SM3016B - Double ended, ¼” dia. As I read through the User Manual that came with the drive it states that one should choose a motor with rated current of 3.5A or less and that has a rated winding inductance of 2.5mH to 3mH if maximum power output (>100W mechanical)is a requirement. Does the lower inductance of the motors i have present a significant problem? I'm fairly sure I've done the math right to determine that i need a 40v power supply to get the maximum speed from these steppers, but I'm unsure of the current I'll require. Do I multiply 3A for one phase by 3 since it's to be a 3 axis system? resulting in a 5.4A requirement? Is a fan cooled case a necessity with this drive? The manual states no heatsink needed below 40C. I'd really appreciate any help, guidance or corrections. thanks, -Hephaestus |
A 6 amp power supply should be fine.
| Thanks Gerry, I believe that's my last hurdle of discovery before constructing my power supply. I'll be hunting down parts in the next few days. I am rather concerned about the motors I have having an rated winding inductance outside the recommended range of the G540. I don't know if this will cause me significant issues and if it will, if they're issues I'm prepared to live with. I'd really like to get this sorted before I get too far into construction of my PSU, just in case i have to replace my steppers. Thanks again Gerry Any advice on the remaining issue would be greatly appreciated. -Hephaestus |
| I don't believe the lower inductance will cause any problems. You might want to call Gecko, or ask on their Yahoo group (Geckodrive) to be sure.
| Brass vs Aluminium Vs Steel, questions, questions and questions... | alexccmeister | General Metal Working Machines | 25 | 08-15-2011 12:40 PM |
| Hot G540 | jdemille | Gecko Drives | 1 | 05-08-2009 12:40 PM |
| can you... BOB to G540? | Fixittt | Gecko Drives | 7 | 01-28-2009 06:37 AM |
| G540 - WOW! | LaserImage | Gecko Drives | 6 | 12-04-2008 03:30 PM |
| A couple of G540 questions | cyclestart | Gecko Drives | 11 | 10-14-2008 12:51 AM |
