Hello, Trying to get a G540 running and have a few questions: 1) The power LED is not lighting (but the fault LED is on RED). I assume the power LED should be on whenever the G540 has power (even if it's in fault). Is this true? 2) How can I determine which rev of the G540 I have? There is no serial number or rev number on the unit that I can see, but there is a hand-written "I9" on one end of the front panel. Also, there is a front-panel mounted charge pump slide switch, if that matters. Thanks for any info. - Steve |
| Steve, The green light will not come on until the G540 eStop switch is connected and it see's a charge pump signal. (unless the charge pump switch is turned off) . If it has a 9 written on the front cover it is relatively new. I just finished a conversion a few weeks ago and the customer purchased directly from Gecko within the last 2 months. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| G540 Power Supply Requirement | samim | Gecko Drives | 3 | 07-19-2009 11:37 AM |
| Best Power Supply for the G540 | Jason Marsha | Gecko Drives | 5 | 05-26-2009 08:38 AM |
| g540 and power supply | chrisw765 | Gecko Drives | 3 | 04-26-2009 10:47 AM |
| can you... BOB to G540? | Fixittt | Gecko Drives | 7 | 01-28-2009 06:37 AM |
| Gecko G540 Drive Power Supply | SSfab | Gecko Drives | 31 | 01-11-2009 07:34 AM |
