Old 10-17-2009, 04:59 PM
samsagaz is on a distinguished road
Motors to use with G540.
Hi guys, i want to know wich motors recommend me to use with Gecko G540.
I want to build an 3 or 4 axis machine of like 1mt x 1mt regards
Old 10-17-2009, 07:02 PM
Kelinginc is on a distinguished road
Here is the designed motors for G540
http://www.kelinginc.net/NEMA23Motor.html
http://www.kelinginc.net/CNCNEMA23G540Package.html
Old 10-19-2009, 09:21 AM
Jeff-Birt's Avatar
Jeff-Birt is on a distinguished road
You should choose the motors to fit your machine, then choose the drive that fits the motors and then a power supply that will work with both. If you try to fit the motors to the drive then you will likely not get the best ones for your machine.
I've seen lots of different machines driven with a G540: benchtop mills, smaller 3'x4' routers to large 4'x8' routers. The trick is always sizing the motor to the machine.
Jeff Birt
Old 10-21-2009, 10:51 PM
i tryed to contact you many times via email and dont get any answer
Old 10-21-2009, 10:53 PM
I see, i will build two machines, both to work with metal.
One for small size iron, for example an table of 20x40cm, and another that will be something like 20x100cm. Can use the same motors, or need to purchase diferent ones?
Old 11-06-2009, 10:20 PM
draughted's Avatar
draughted is on a distinguished road
look for a motor in the NEMA23 under 3.5amp
i use 269oz-in with a rating of 3amp
Old 11-07-2009, 01:59 PM
This motor is for G540, KL23H284-35-4B (1/4” Dual shaft with a flat) 387 oz-in
Old 11-07-2009, 02:30 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
The 381s are a better match for the G540 than the 387s. This is what I recommend:
$147 Three $49 KL23H2100-35-4B 381 oz motors for X, Y & Z
$060 One KL-350-48 48V/7.3A power supply.
$010 Estop switch
$007 3 Home switches
$009 Straight thru parallel computer cable.
$233
CR.
All of this is available from Keling:
http://kelinginc.net/
Old 11-07-2009, 03:25 PM
Kelinginc are you receiving my emails?
Regards
Jose Luis
Old 11-13-2009, 04:09 AM
fretsman's Avatar
fretsman is on a distinguished road
Jose,
Just wanted to drop in and say the service I've received from Keling is great so it must be an email problem as I always receive return emails from them promptly.
Dave
Dave->..
Keiling motors and G540 connections Help bevins Automation Technology Products 4 09-04-2009 03:59 PM
Config for 2 motors on x-axis (w/ Gecko g540) rogerer LinuxCNC (formerly EMC2) 5 05-16-2009 09:30 PM
Need Help!- Need Motors for G540 bd007 DIY-CNC Router Table Machines 0 03-23-2009 07:00 PM
Need Help!- Looking Stepper Motors for G540. samsagaz DIY-CNC Router Table Machines 10 03-22-2009 04:46 PM
I can't get my keling 387oz-in motors to step evenly with my G540 codevark Gecko Drives 0 03-16-2009 11:32 PM
