Old 09-30-2009, 02:27 AM
quickerz is on a distinguished road
Encoders for Gecko drive
Hi all.
I have a question regarding encoders for Gecko 320 servodrives. Will encoders as seen in attatched datasheet work with the 320 servodrive?
John
Old 09-30-2009, 04:33 PM
diycnc is on a distinguished road
that doesn't look like it would be easy to mount or hook up.. i cant say if it would work thou
http://search.digikey.com/scripts/Dk...02-V&x=18&y=15
these are recommended as you can change the resolution. i got the us digital ones and wished i would have gotten these
___________________________________________________________________
http://www.cnczone.com/forums/showthread.php?t=86985 my work in progress
Old 10-01-2009, 04:59 AM
Ok.
They are already mounted on a type of motor. it says that they are ttl compatible. Maybe I should contact Gecko to be sure.
Old 10-01-2009, 05:20 AM
how many line are they? with the non selectable error range on the older geckos much more than 500 line the drive errors out in a really short distance. if you have the new drive this shouldn't be a problem.
looking at the specs it seems to be under the current rating and of the correct type.
Old 10-02-2009, 09:11 PM
Gold Member
Mariss Freimanis is on a distinguished road
The pdf you supplied says the device needs 65mA at 5VDC. That knocks it out of the water right there because the limit on what the G320 can supply is 50mA.
Mariss
Old 10-03-2009, 09:06 AM
cant you just power them separately and use a resistor in the gecko?
Precautions for Use
( 1) This module is designed to be operated at I F = 30mA TYP.
(2) Fixing torque : MAX. 0.6N • m
( 3) In order to stabilize power supply line, connect a by-pass capacitor of more than 0.01µF between Vcc and GND near the device.
( 4) As for other general cautions, refer to the chapter “ Precautions for Use . ”
Old 10-07-2009, 08:43 AM
metron9 is on a distinguished road
Mariss
Actually that is an absolute maximum rating. The device requires external resistors to reduce the current for the internal led (1 Anode/2 Cathode) to 20mA. The maximum it should operate at with both output A and B at low (Sinking current) should be 30mA.
Old 10-25-2009, 09:26 PM
lavrgs is on a distinguished road
I'm try to use those CUI AMT102-v with a G320x but I can't get them to work. I'm not sure where the problem is; I mis-wired it first but got that fixed. The voltage on the A & B lines go from 4.9v down to .5 but when I spin the motor the drive faults out...
Old 10-27-2009, 06:33 PM
dgoddard is on a distinguished road
I just completed hookup/tuning of the AMT-102 with the G320X and it works well. Will use this encoder for future needs. Did call Marisis couple of times just to clarify and guidance as this was my first wiring of a drive. With his help it when smoothly following installation instructions.
Old 10-27-2009, 07:33 PM
Did you glue the plastic adapter to the shaft? I think that my problem is caused by slippage...
New Machine Build- BOB that can step drive and handle encoders xkadet Controller Cards 1 12-02-2009 05:32 PM
Gecko Drive Don Kellogg DIY-CNC Router Table Machines 8 08-10-2008 12:12 PM
Possible Gecko Drive? juzwuz Gecko Drives 7 03-19-2008 11:00 AM
differential encoders with Gecko G320 jed102 Gecko Drives 4 10-02-2006 04:37 PM
Gecko G320 Wiring Diagram w/servos and encoders CJL5585 Gecko Drives 0 11-18-2005 04:42 AM
