Old 09-24-2009, 07:58 AM
nerginer is on a distinguished road
power supply
I have 4 gecko340 and a 67 volt (48ac*1.4)dc powersupply. I have 3 motor which is suitable to use at that voltage but one of the motor is 24v. What is the best way to reduce the voltage to 24volt. I use serial resistor with the motor but it produce so much heat.
Regards,
Nuri Erginer
Old 09-25-2009, 08:45 PM
Gold Member
Mariss Freimanis is on a distinguished road
Do not use a series power resistor anywhere! 24VDC motors should be OK with a 48VDC supply so long as you set the LIMIT trimpot to your motor's max current rating and you don't ask your CNC program to run the motor past the motor's rated RPM. Get rid of the resistor, it can damage things!
Mariss
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power supply help bigvinney General Electronics Discussion 1 01-20-2006 07:42 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
Power Supply Help beausdn Open Source Controller Boards 4 11-15-2004 03:22 PM
