Old 03-09-2005, 06:46 AM
LeeWay's Avatar
LeeWay is on a distinguished road
What's needed for complete setup?
I was wondering what is needed for a complete Gecko setup. I noticed in the manual that other things are needed. What might these be? Where might I locate them?
The problem- I was testing the motors last night and we neglected to cap all the center wires from my motors. My contoller was a Xylotex 3 axis drive.
One of the motor wires shorted out on my controller case and smoked the Xylotex. Anyway, a fuse may have prevented this mishap, but the manual says not to put fuses on the system.
At any rate, I understand that I can get this board repaired possibly.
I am wondering if it might be btter to go with a Gecko system, but need to know what a system involves cost wise.
My motors are 2.8 amp at bipolar, which is a little too high for the Xylo. Should I spend my money on a second Xylo as a backup or go with Gecko? Help me choose please.
Lee
Old 03-09-2005, 08:38 AM
ger21's Avatar
This might not help with your decision, but the Gecko most likely would have smoked as well.
You'll need three Geckos, preferably a breakout board and most likely a new power supply. If your going to get Geckos, use a higher voltage supply to take better advantage of them. Without a higher voltage supply, the performance increase would be very small.
Turbo CNC Not Running.... Setup? Davedbq TurboCNC 4 02-04-2005 01:20 PM
Boss 5 help needed rsr911 Bridgeport and Hardinge Mills 4 10-27-2004 12:10 AM
Setup instruction dgb General Metal Working Machines 1 09-06-2004 06:39 PM
Taig CNC ready setup help?? efreak Taig Mills & Lathes 2 08-24-2004 07:30 PM
How to change the setup sheet format? cwww General CAM Discussion 2 06-30-2004 02:28 PM
