Old 08-23-2009, 09:06 PM
Jackal66 is on a distinguished road
How do you drive large steppers?
I saw in the post at the top about "Stepper FAQ's"
In there, is this statement:
Method 2: You have a Bridgeport CNC conversion you are doing. The machine has a 5 TPI screw and you need a work feed rate of 120 IPM. 120 IPM on a 5TPI screw 5 * 120 or 600 RPM.
How about force? Not a clue? Use your machinist's experience on a manual machine. The hand crank is about 6" inches in diameter. How much force would you place on the hand crank before you figure you're not doing something right? I hear about 10 Lbs.
10 Lbs is 160 oz, 160 oz on the end of a 3" moment-arm (6" diameter, remember?) is 480 in-oz (3 times 160) of torque on the leadscrew.
The equation for rotary power is: Watts = in-oz * RPM / 1351
For this example, Watts = 480 in-oz * 600 RPM / 1351 or 213 Watts.
213 Watts is servo territory. You have to use a servo motor to get that, about a NEMA-34 one.
So then, how do people drive those 1200 oz./in. to 2380oz./in rated steppers????
Is there something missing in the rating of the steppers? Are they misrepresented & the evaluation in an RPM range the motor never really sees?
Could the motors be tested on a scale that shows higher level because their competitors don't use the same category?
I am just wondering if there is a standard, for power and the high numbers are in another class, that other manufacturers never use?
My thinking is 25-30 lbs torque on a Bridgeport wouldn't be uncommon.
Is this much torque irrational, for a machine this size?
Thanks in advance and let me know,
JAckal66
Old 08-24-2009, 02:28 PM
No answers yet?
JAckal66
Old 08-28-2009, 07:31 PM
*Registered User*
olf20 is on a distinguished road
I converted my bridge port clone to cnc about two years ago.
I did not know nothing about anything. I contacted Rick at homeshopcnc.com.
He was very helpful.
That being said I used the 1200 oz in steppers with gecko 201 drives.
Ball screws would improve the speed but, does the job for us.
Used 1:1 on the X & Y, 2:1 on the Z.
Power supply 72 volts.
Hope this answers your question.
olf20 / Bob
Old 08-30-2009, 10:17 PM
Thanks Bob,
So then, the Gecko drives will work on the large steppers. I figured you had to have some special or custom made drivers for the large steppers.
That clears up a lot.
Can anyone else that is running large steppers, list the motor size and drivers?
Thanks,
JAckal
Newbie- Large salvage steppers for first project. Asymetric Stepper Motors and Drives 7 03-30-2009 06:44 AM
Steppers and controller to trade for one large stepper. Dazza Australia, New Zealand Club house 0 07-09-2008 09:07 PM
Large Sigma steppers? DennisCNC Stepper Motors and Drives 0 03-17-2007 07:08 PM
need to replace my large 1200oz-in steppers with smaller one with less cogging/detent Apples Stepper Motors and Drives 9 02-15-2007 01:34 PM
How large steppers do I need on a Taig mill?? jaru-eri Taig Mills & Lathes 0 07-29-2006 07:34 AM
