Old 08-22-2009, 08:02 PM
mayhugh1 is on a distinguished road
Question about Drive Supply current
I have two 103-807-6341 Sanyo-Denki steppers. The nameplate says 3.02A but a data sheet I found on the web says the bipolar parallel current is 4.3 A, and it also specifies the unipolar current at 3.05A. I'm trying to select the driver supply current to run two of these drives in bipolar parallel with G201's but I'm getting confused with phase current and total motor current.
My question is whether the current spec is typically the entire motor current or is it only a single phase which is how the resistance and inductance values seem to be specified. If only to a single phase then do I need to double the value to get the total current requirement for one drive? And then double again to get the requirement for two drives? Also is the current limit that is to be set on the G201 also a phase current or the total motor current?
Old 08-23-2009, 02:33 PM
Gold Member
Mariss Freimanis is on a distinguished road
The actual power supply current draw depends on motor load and speed. It can be as little as 0.3A at moderate speed and no load to as much as 2A when the motor load is just short of stall. Use 2A supply current per 3A per phase motor axis.
Mariss
Old 09-24-2009, 07:36 PM
niner is on a distinguished road
Mariss,
I want to be sure before I order. Will G540 work with these Sanyo Denki steppers? I have the same motors (103-807-6341) in my lathe. Each phase is wired in series.
Old 09-24-2009, 08:05 PM
Gold Member
Ah,.. can you provide a data sheet pdf or url where I can find specs on this motor? Help me out here; I just hate to have to hunt down another motor model number specification.:-)
Mariss
Old 09-24-2009, 08:11 PM
Sorry, I should provide it in the first place.
http://www.rtaeurope.com/pdf/eng/4ing.pdf
Please also suggest the value of current set resistor. Thanks!
Old 09-25-2009, 07:38 PM
Gold Member
niner,
Wire your motor in parallel, get a 3.48K current set resistor (digikey.com digikey part number 3.48KXBK-ND for minimum of 5 resistors at $0.10 each) for the G540. It should work OK then. Use a 48VDC power supply to get the most from the motor.
Mariss
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
DC Por Supply Drools General Electronics Discussion 2 08-16-2009 07:32 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
PWR supply help DSL PWR General Electronics Discussion 35 11-06-2005 09:43 AM
supply ? mdreitzusa General Electronics Discussion 17 08-27-2005 03:04 AM
