Old 08-13-2009, 10:04 PM
mayhugh1 is on a distinguished road
Help Minimizing Chance of Lost Steps
Given a stepper motor controlled lathe, G201's and Mach3, which of the following is best practice for writing g-code in order to minimize the probability of lost steps and degradation in accuracy: 1) accelerating the cutter (z or x axis) into the workpiece from a resting point very close to the workpiece so that the steady state ipm is reached while cutting, or 2) accelerating the cutter into the workpiece from a resting point which is far enough from the workpiece to allow the cutter ample time to reach its steady state ipm value outside the workpiece. My intuition says number 2, but stepper motor torque vs rpm curves seems to say number 1. Some experimental data I took seems to say it probably doesn't matter - or else I have more than one issue. I own a lathe that needs to be babied to maintain even a few thousandths accuracy and I'd like to do anything I have some control over to improve it. I'm afraid the motors just aren't up to the job. - Terry
Need Help!- Lost Steps? IAD Mach Mill 11 08-07-2008 07:36 AM
X3 Lost Steps pzzamakr1980 Benchtop Machines 21 04-20-2008 10:43 AM
Engraving and lost steps... Parameter Stepper Motors and Drives 21 12-12-2005 12:06 AM
Lost Steps boxwood Machine Problems, Solutions , Wireless DNC, serial port 7 07-09-2005 09:26 AM
help with lost steps?? chrisw765 Xylotex 4 06-16-2005 03:59 PM
