I just wanted to pass this along to anyone having issues with the fault condition on a new system. Conditions at the time of the fault: No motors connected. Newly rebuit XP machine on a mini desktop with a deticated parallel port Was able to find and set the EPP for the parallel port in the bios setup. had limit switches and an e-stop switch and 36V power applied to the unit. Newly loaded copy of Mach3 Settings for the charge pump all per the manual. Charge pump on-off switch had no effect on fault. Reading all the posts with no help.... Then I noticed someone wrote about a short lead to the e-stop. disconnected the e-stop switch and wired it directly to -VDC. (which is bascially what the switch was doing). Drive fault gone. Motors up and working. Mach3 working with the help of the xml config file for G540. I'll eventually have to figure out what switch to use that doesn't cause this fault. |
| newbie help - g540 fault lite on | guycrunch | Gecko Drives | 6 | 07-11-2009 06:27 PM |
| G540 Fault | matttay | Gecko Drives | 9 | 05-05-2009 01:41 AM |
| G540 absolutely will not come out of FAULT mode... PLEASE HELP! | Farasien | Gecko Drives | 8 | 03-03-2009 08:22 PM |
| Need Help!- G540 Fault light | cnccustom | Gecko Drives | 14 | 01-06-2009 12:53 AM |
| G540 fault problem | jemmyell | Gecko Drives | 12 | 10-21-2008 05:50 PM |
