You must have reversed the supply polarity. That is guaranteed to the blow the internal fuse. Good news is the G540 is unharmed.
Mariss
I have just wired up my 540 drive. I have checked all connections several times and all is as required, ie 35vdc arriving at pins 11 & 12 polarity is correct, pins 10-12 wired via an NC emergency stop, charge pump setting enabled on pin 16 all step and drive pins enabled as per instructions. Unfortunately I get no indication of life at all, no power light, no fault light. I tried inducing a fault light by going open circuit on pins 10-12 but no fault light. Did I blow a fuse, is there a fuse????. Help Please
Mariss
Thanks Maris, I'll take the back of the Gecko today and check. Can you confirm that the back is just pressed on as I see no securing screws. Thank you again for your help...regards Rod
Hi Mariss, I've taken a look but I don't think that there is anything I can do here, I guess i'll have to send the unit back to you to check for me. thanks...Rod
