Old 07-27-2009, 02:20 PM
m1911bldr is on a distinguished road
A little advice on an upgrade?!
I've got a 40(x) x 30(y) stepper driven router. I am using dual drive motors on the "X" axis to eliminate racking of the gantry. It runs very well MOST (90%+) of the time. Every once in a while, the X motors will stall during acceleration from a stop if the current reduction has kicked in. I'm currently using Hobby CNC's Pro driver board and their 305 oz-in motors. I also have a CNC4PC board that I'm using to provide step and direction signals for a second "X" motor driver instead of using MAch 3's slaving function. My gantry weighs about 25 pounds, router and all. Will a Gecko improve the reliability of my X axis motors? Which one should I use (knowing I'll be using one for each of the X motors) and what capacity of power supply? I'm inlaying custom cutting boards and if the router screws up in the middle of pocketing the board for the inlay, the board's in the trash!
Old 07-27-2009, 02:27 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
M1911bldr,
Have you read this thread?
http://www.cnczone.com/forums/showthread.php?t=49043
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 07:03 AM
Upgrade Advice dighsx Gecko Drives 7 05-18-2006 07:32 PM
AutoCad Upgrade advice/options.. hotponyshoes Autodesk Software (Autocad, Inventor etc) 5 03-15-2006 04:17 PM
Vmc 40 -5 upgrade redman Fadal 14 11-18-2005 07:22 PM
Advice / help? - HobbyCNC upgrade for SpectraLight 0200 Sporqster Hobbycnc (Products) 1 06-15-2005 09:55 PM
