I am a bit lost here. I am trying to use my g540 to turn on and off my spindle (bosch router) through mach3. I have a 50v psu and a 115v relay with a 12vdc trigger. How do i hook it up with the pin 5,6 outputs to trigger the relay coil? do i need a 12vdc psu as well?
__________________ Nick I Know I Cant Spell..Don't Remind Me |
| The 540 has two relay outputs on pins 5 & 6. These are switched grounds so you hook one side of the relay coil to pin 5 OR 6 and the other to the 12v+ PSU. The 12v PSU ground line should be tied to the stepper motor PSU ground according to the Gecko Blurb! |
| Ok i am going to just try it and see if i understand. So ive got 50vdc and Ground from my main psu to the gecko on pins 11-12 i think it is. Im going to have to add a 12vdc psu right. From here im going to run +12vdc to one side of coil and then -12vdc to pin 5or 6. Then hook -12vdc wire from psu to ?? ground on the 50vdc psu??(where the gecko is grounded) or am i completly lost here? Sorry Nick
| There's a wiring diagram in the back of the G540 manual and it covers adding relay control to pins 5 and 6. If you follow it, you should be OK.
__________________ Regards Geoff |
| I recently started carrying some 48V relays to make it easier on folks with G540s: http://cnczone.com/cncparts2.aspx. Just hook one side of the coil to your +V supply and the other side to the G540 output.
__________________ Jeff Birt |
| G540 Spindle speed output voltage problem | georgef8 | Gecko Drives | 5 | 09-22-2009 10:18 AM |
| g540 | Scooby Doo | Gecko Drives | 62 | 05-17-2009 01:44 PM |
| Hot G540 | jdemille | Gecko Drives | 1 | 05-08-2009 12:40 PM |
| Need Help!- Output command for g540 | DanOSB | Gecko Drives | 3 | 02-19-2009 09:06 PM |
| can you... BOB to G540? | Fixittt | Gecko Drives | 7 | 01-28-2009 06:37 AM |
