Do you forsee any big problems with using the G540 to slave two x axis steppers together for a small gantry system? I have never actually tried to do that with steppers (or servos) so might be missing some aspect that makes it difficult. I want to make a little compact gantry out of a bunch of thk KR series ballscrew actuators and the simplest bolt together solution would be to use two for the x axis, one on each side, both driven. Since the G540 is 4 axis, this seems a simple elegant solution. |
| It is very simple. Just sellect "Slave Axis" from the config menu. In the left X-axis coloumn you just mark the A-axis as the slaved axis. All signals sent to the X-driver are now also directed to the A-driver. Remember to restart the program. |
| ^^^^^^^^^^^^^ AND be very careful when you first try to move your slaved axis... if one motor moves north and the other south things might break, don't ask how I know.... and I thought I was being careful. You can reverse the slaved axis in the Config>Homing/Limits... or reverse a phase of your stepper. |
Well, I finally figured out what the problem is. The 4th Axix stepper driver in my Gecko is bad. I took the X and A axis boards and swapped them out, restarted mach3 and guess what happened? The A motor turned and the X did not. Just to be on the safe side, I tried a different motor on the X axis, no joy... So Gecko Folks, if you are watching, I need a new driver board! Qualls |
| I thought the G540 was nearly bulletproof.... good thing you tried this little exercise, else you could drive yourself crazy trying to figure out what's hooked up wrong (being a noob, i would assume it was something I did wrong). Sounds like it will be pretty easy to fix though. |
#10
| Well, I guess that's the good thing about the way the G540 is built. It comes every bit as much of a surprise to me as it does to everyone else. We had a customer that totally blew out the X axis drive. It smoked and caught on fire kind of blew out. The drive was totally toast. It stank big time and so did the G540. We removed the X axis drive and plugged the G540 in. Nothing was expected from it because the damage was so extensive. It ran. It ran flawlessly (on 3 axis). It surprised me and our technicians. We washed the boards (detergent and hot water), replaced the fuse (it had been subverted with a wire shunt) and placed it in an oven set to 100C to desiccate the parts. The G540 was replaced with a new X-axis drive. Washing was required because anytime there is a fire the residue is acidic and corrosive. It passed all new G540 tests on the test stand. This was as nasty of a G540 failure as I have ever seen. It still ran without a problem once the dead X-axis drive was removed. Mariss |
| Motor Tune and Slaving?? | finishlinewrx | DIY-CNC Router Table Machines | 6 | 05-19-2009 01:31 PM |
| Slaving axis & other issues | George | Mach Mill | 5 | 04-17-2009 03:19 AM |
| can you... BOB to G540? | Fixittt | Gecko Drives | 7 | 01-28-2009 06:37 AM |
| Slaving 2 axis together Mach3 | retromulticam | Mach Software (ArtSoft software) | 1 | 04-29-2008 07:42 PM |
