So today I go out and turn on the power to my plasma table to do some cutting and the fuse for the X blows. I unplug the motor and put a new fuse in and it does not blow until I hook the motor back up. I swapped the X and Z motors and same thing, it just blows the fuse. So I took out the fuse and put a 30amp fuse in it and it let all the smoke out of my G201. I swapped the x and Z motors and the X motor still works just fine hooked up to the Z drive. I took the cover off and the only thing I could find wrong was it split one of the resistors in two. The weird thing is that I have had this table running for over a year without any problems. Everything worked great last week when I used it last. Can the drive be fixed? I can solder in parts if that's all that is wrong. I am using Homeshopcnc steppers and a Candcnc THC with there BOB. |
| Fuses blow when things short, not because they get weak or are rated wrong. Typically the power FETS on the bottom of the board go first. Sometimes things just fail. The resistor that blew apart shows what happens when you pass huge amounts of current through a low ohm resistor! A 30A fuse will not blow instantly unless it gets a 200% overload. It's repairable unless it damaged the board (and that much current could do that easily). When FET's blow they typically short from Drain to gate and take out the gate drive components. The cost to fix everything may exceed the value of a new drive. Good news is a replacement won't cost you too much. There may not be a reason (something besides the drive being defective) that caused it and you proved it was not a shorted motor when you hooked the motor in question up to a good drive and you didn't end up with two blown drives. ![]() I would replace the drive, make sure you have heatsink compound on the bottom and have some airflow across the heatsink and go back to cutting. Most likely nothing else is damaged. The opto inputs would protect the upstream components (MP1000 box). Tom Caudle www.CandCNC.com |
| Smoke in my shop | Twistr | General Metal Working Machines | 5 | 10-19-2007 12:58 PM |
| did i smoke ya ! | superrotary | I.C. Engines | 1 | 09-28-2007 11:26 PM |
| Why did the smoke escape? | obscurity | Stepper Motors and Drives | 5 | 05-28-2006 11:34 PM |
| no smoke but............... | turmite | General Electronics Discussion | 14 | 12-06-2003 05:27 PM |
| Smoke and sparks? | Marc Soren | General Electronics Discussion | 0 | 10-13-2003 07:46 PM |
