Old 06-03-2009, 05:13 PM
Vrogy's Avatar
Vrogy is on a distinguished road
G320 + HEDS-5540(encoder)?
I'm retrofitting an older mill which was driven by geared-down servomechanisms.
The encoders on the motors are HEDS-5540, either by Agilent or HP- a pdf I found on them is branded with Agilent, but they have an HP icon molded into them.
http://www.techshopdurham.com/wiki/uploads/HED-series optical encoders.pdf
The problem is, the G320 wants an encoder +, -, and phase A & B. The encoder puts out those, but also a channel I, for counting the index, or a full rotation.
Should I ignore this lead, can the G320 not make use of it?
http://flickr.com/photos/vrogy/
Old 06-03-2009, 06:24 PM
Bubba's Avatar
Bubba is on a distinguished road
Yep, ignore it! There is no input on the Gecko to use it.
Art
Old 06-04-2009, 12:20 PM
keebler303 is on a distinguished road
Bubba is correct, you could however tie the index pulse to an input on your breakout board and use it for homing. A lot of commercial machines go until they hit a limit switch, then reverse until they get to the index pulse on the encoder. This gives you a repeatable zero within 1 encoder count. Could be much better than a switch setup, depending upon the type of switch you use.
Matt
Old 06-04-2009, 12:28 PM
Bubba's Avatar
keebler,
Not trying to hi-jack, but I think?? it will take a tad more than just tying the index to the BOB!
Art
Old 06-04-2009, 02:18 PM
Obviously, you need to setup Mach or whatever controller you use to do that homing routine. I was not trying to be terribly explicit, just mentioning the general concept. The point I was trying to make was that although the G320 doesn't use the Index, it is useful, but only if you actually connect it to an input on your BOB.
As long as 5mA is enough to activate an input on your BOB (optocoupler might take more) then all you need is the index signal and the common from the encoder.
Matt
Old 06-04-2009, 03:04 PM
Bubba's Avatar
keebler,
Thanks for the clarification as you and I are actually thinking along the same lines. I just didn't want somebody out there to get the idea they could hook the index to their BOB and have instant gratification!
Art
encoder cpr ?? g320 chrisw765 Gecko Drives 1 03-08-2009 11:54 PM
UNKNOWN ENCODER & G320. salman Gecko Drives 0 01-02-2008 10:45 AM
Looking for info on HEDS-5310 encoder tphillips Servo Motors and Drives 10 12-06-2007 04:56 AM
Need info on HEDS-6300 encoder. Sorta... Fifty_ohm General Electronics Discussion 0 12-14-2006 07:31 PM
HEDS-9100 encoder modul giorgiocnc General Electronics Discussion 4 09-11-2006 03:04 AM
