Old 06-03-2009, 02:45 PM
revwarguy's Avatar
revwarguy is on a distinguished road
Misc. stuff on the G540
I've documented some info on the G540 that I couldn't find elsewhere. Hope this helps someone else.
Its at
http://www.liming.org/cnc/540.html
Old 06-04-2009, 10:09 AM
madtownrob is on a distinguished road
Nice write up on the G540 and great build log on your website. Your heavily modified Solsylva came out a heck of a lot better than mine did!
You keep mentioning that you got those temperature displays/sensors for $3/each - can you post a link to where and share the wealth? Thanks!
- Rob
Old 06-04-2009, 10:45 AM
revwarguy's Avatar
The temp displays are actually $3.95, not $3.00 - my fault, I will change it on my site.
They are at:
http://www.mpja.com/prodinfo.asp?number=16370+ME
Don't know how much they will tell me , but I should have a good handle on overheating!
Old 06-17-2009, 10:03 AM
Fixittt is on a distinguished road
REV,
I enjoyed your site and the video. can I ask this? why are you crippling your setup with only a 24 V PSU? Add a larger PSU and you will get better performance from the steppers.
If and when you start cutting and get stalls on your steppers. Look at this as a source. Other then that man, GREAT SITE AND MACHINE!!!!
Old 06-23-2009, 03:25 PM
revwarguy's Avatar
Well, as I mentioned on the blog, the 24V supply was cheap. The major cost of a linear PSU is the caps, especially since I already have a xformer and a bridge. If it starts to stall out under load, I will look at that. I appreciate the advice.
Old 12-01-2009, 11:13 PM
absolutepoker01 is on a distinguished road
thanks rev for the info, a lot of new stuff!
Old 07-16-2010, 08:38 PM
ghostlx's Avatar
ghostlx is on a distinguished road
revwarguy
how did you wire up your limit and home switches ? I have red the gecko way and the homans way . still trying to decide how to wire them up . I would like to have a mpg pendant and a touch probe too. and the 540 only has 4 inputs.
any thought on this
thanks for your time
ghostlx
http://www.pure-teck.com/home.html
My KX3, tweaks and misc. stuff Guldberg Benchtop Machines 3 03-26-2009 10:20 AM
question about leadscrews and misc. X1 stuff... WRMorrison Benchtop Machines 3 03-30-2007 11:26 PM
Mach3 tuning (cuts small stuff fine, but is off on big stuff) jdbaker Mach Software (ArtSoft software) 4 03-15-2007 11:30 AM
Misc surplus controllers, need help Hobbiest General Electronics Discussion 7 03-19-2005 12:54 AM
welding thick stuff to thin stuff - need advice cross6 Welding, Brazing, Soldering, Sealing 5 01-13-2005 01:39 AM
