Old 06-02-2009, 02:50 AM
gavztheouch is on a distinguished road
G320 and Encoder compatability?
I have an encoder with A+ and A- and also a B+ and B-.
So I have 4 wires that I need to connect to the 2 encoder terminals on the G320. Should I wire both A+ and A- onto the same A terminals?
Cheers
Gav
Old 06-02-2009, 07:22 AM
Bubba's Avatar
Bubba is on a distinguished road
ignore the A- and B- as they are the inverted signals of A and B respectively. Also, verify the current draw on your encoder. I must be 50ma or less to be powered from the Gecko, If it is more, you will need to provide a separate power supply and follow the instructions which can be found on their web site.
Art
Old 06-02-2009, 08:31 AM
asuratman is on a distinguished road
What need to take attention to get encoder compatible with gecko 320. I have a plan to buy hanyoung (korean made), it is rotary encoder, how do I know that this encoder work with g320?
encoder cpr ?? g320 chrisw765 Gecko Drives 1 03-08-2009 11:54 PM
UNKNOWN ENCODER & G320. salman Gecko Drives 0 01-02-2008 10:45 AM
encoder question for G320 CNC Darren Gecko Drives 7 11-15-2007 12:14 PM
G320 and Grex Encoder and Err/Res Hookup... 54Oval G-REX 0 04-06-2007 11:31 PM
encoder question for use on G320 Runner4404spd Gecko Drives 0 12-08-2005 10:32 PM
