I have a gecko G540. Is it ok to use standard computer DB9 cables as the motor cables. I have 8 wire 3.5a steppers and was thinking chop one of the moulded ends off the db9 cables and connect straight to motor wires and the other end to the gecko G540? The DB9 cables I have the individual metal core wires are 0.4mm dia but the motor wires core is 0.8mm. would it take the amps? |
| I have built at least 35 G540 systems if not more. I use standard DB( 6ft cables. But I have found that not all standard db9 cables made by various chinese manufactureres are good. I have had some that got very hot even though the motor was just warm. This was about the time that copper was really expensive and I think they cust the wire gauge. On other cables I have found that you couldn't remove the screws that are on the side of the cable that connects to the motor. The db9 connectors shells require the screws be inserted from that side. Last I ran into a couple cables that would get very warm and cause intermittent faults. When the cable was replaced the problem went away. So I only buy my cables from a given source that I know doesn't have problems. Dan Mauch Camtronics Inc www.camtronics-cnc.com low cost cases for the G540 and other fine Gecko products. |
| I use to get them from MPJA.com but I see they are out. I have ordered some from another company but they haven't arrived yet so i can't answer if they are any good.. |
| I use to get them from MPJA.com but I see they are out. I have ordered some from another company but they haven't arrived yet so i can't answer if they are any good.. Dan Mauch dmauch@camtronics-cnc.com gecko G540 cases and other fine products. Camtronics, inc. -- CNC with Dan Mauch |
#10
| We sell cables that are custom made for us, 20 AWG DB9's specifically for motor applications with the G540. Best of luck! Ahren CNCRouterParts |
#11
#12
| I was just alerted to that thread the other day, and was quite surprised to hear this from Gecko. We have sold hundreds of kits with the current set resistors in the motors, some even on 20' cables, and have not had any performance issues. I have definitely seen issues with cheap serial cables, and have replaced many of these with our own cables. That being said, if someone is nervous about having the resistor farther from the drive, it is fairly straightforward to cut off pins 1-5 on the cable connector, and crimp some pins to a current set resistor inserted directly into the drive. This will be, in my opinion, far more robust than a lot of DIY cables made by those with questionable soldering skills (myself included!) Best regards, Ahren CNCRouterParts |
| Powermax II cables | moto21 | Stepper Motors and Drives | 3 | 04-09-2007 03:56 PM |
| Very short cables to Flashcut Servo motors | DonFrambach | FlashCut CNC | 2 | 03-10-2007 12:16 AM |
| Short Cables on Flashcut Servo Motors | DonFrambach | Benchtop Machines | 1 | 03-05-2007 11:15 PM |
| Cables | itsme | General Electronics Discussion | 3 | 05-22-2005 02:35 PM |
| VFD and inverter duty or standard motors | snaggletto | General Electronics Discussion | 4 | 08-01-2004 10:46 PM |
