Old 05-18-2009, 04:54 AM
dougie329 is on a distinguished road
am I ok to use a 48V power supply?
I am running 4 motors at 3.5 amp phase current and have seen a power supply which is 48v, 8.3amp (ebay item number 390048815410).
It has been suggested that 48V is very close to the max voltage, and all it takes is a small amount of BEMF or AC line voltage fluctuation above 230V and the DC may go up above the 50V.
Is this a potential problem or would I be ok here?
Old 05-18-2009, 01:10 PM
CoAMarcus's Avatar
CoAMarcus is on a distinguished road
You will be fine with a 48VDC power supply. When we say 50VDC as a rating we mean 50VDC; the G540 is de-rated to take BEMF and component tolerances into account.
Marcus
Old 05-18-2009, 02:00 PM
thanks for your reply marcus, I will go ahead and order the 48v supply
Old 05-18-2009, 05:58 PM
rowbare is on a distinguished road
Your 8.3 amp supply is a bit low for running 4 motors though. The rule of thumb is 2/3 total amperage thus 4*3.5*.67 = 9.3 amps so you should probably look for a 10 amp supply.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Power Supply! LT1TRUCK Controller Cards 0 09-13-2007 12:44 PM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
