Old 05-16-2009, 09:15 AM
rogerer is on a distinguished road
G540 and EMC2, need help with setup
Hi
Just got a Geckodrive G540 along with a 48volt 7,3amps power supply and four Keling KL23H2100-35-4B steppers.
I hooked up one of the steppers today to the G540 without a current resistor (read somewhere that it would work ok) and used EMC2 ver. 2.2.8 on an Ubuntu computer.
In emc2 I used the standard settings for Gecko drivers. Got it working good, but I have a few questions I hope someone could answer.
In case 1 (attached screenshot with microstep=10) the motor had a velocity of 8550 something (?)when running G0 rapids. Not losing steps I think (how can you see).
In case 2 (attached screenshot with microstep=2) the motor had an (insane) velocity of 45600 something (??) when running G0 rapids and I could not see the motor loosing any steps. The motor would not run feeds under 700 mm/sec (the emc2 program showed movement, but the motor stood still).
What is the appropriate microstep setting? I tried both 2 and 10 in the microstepping option as you can see. What does that number mean, an what are the consequenses of changing it?
ID:	81428   Click image for larger version
Old 05-16-2009, 01:21 PM
Ok, I now realize that the G540 is a static 10 microstepping drive.
EMC2 Configuration File for G540 CoAMarcus LinuxCNC (formerly EMC2) 7 05-22-2009 04:32 PM
G540 & EMC2 Anyone? 725franky Gecko Drives 22 04-20-2009 08:14 AM
trouble with setup of g540 and mach ZNAK Mach Software (ArtSoft software) 1 04-05-2009 08:56 AM
Need Help!- G540 microstepping motor setup mikie Gecko Drives 17 03-18-2009 06:15 PM
Need Help!- g540 setup question don_don Gecko Drives 17 02-16-2009 02:05 PM
