Old 05-08-2009, 01:56 AM
chrisw765 is on a distinguished road
g540 any way to not micro step x10
So I'm setting up my mill and figuring out the steps per inch I'm swapping out the old dos base system on my servo impact mill to mach 3 i bought the g540 but didn't realize its stuck in 10x micro stepping??
my setup
387 nema 23 from keli
so 280 deg
x10 micro stepping =2800
5 to 1 belt drive = 14000 steps
5 turn to one inch ball screw= 70,000 steps per inch !!!!!!
that's a lot I'm not sure what mach 3 can even do I'm running a due core 2.4g
Old 05-08-2009, 02:06 AM
my bad
200 steps per rev not 280 i miss read 2.8deg==brain fart
so that brings it down to 50,000 steps per inch thats still a lot?? tho
or is that normal ??
Old 05-08-2009, 02:50 AM
jalessi's Avatar
jalessi is on a distinguished road
Question
Chris,
Why are you using 5 to 1 belt reduction with the ball screw?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 05-08-2009, 09:29 AM
im just using what came on the mill, it has nema 23 ac brushless servos on it now,im just swaping the old servos with new steppers so i can run mach3 .. its how the factory has it set up..
Old 05-08-2009, 10:23 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Servos are HIGH RPM motors and are usually geared down to trade speed for torque.
Steppers are LOW RPM motors and are usually mounted direct drive or 1:1.
Running steppers at 5:1 gearing will effectively neuter them. Change the pulleys to one to one ratio.
CR.
Old 05-08-2009, 03:39 PM
jalessi's Avatar
Post
Chris,
Crevice Reamer is 100% correct, either change the pulley to 1-1 ratio or remove it and attach the stepper directly to the ball screw.
Jeff...
Old 05-08-2009, 05:28 PM
Gold Member
Mariss Freimanis is on a distinguished road
Chris,
Go 1:1. With 5:1 you are putting 1,935 in-oz (13.7 Nm) of torque on your screw. It in turn is producing 3,800 Lbs (1,730 kg) of thrust. That's almost 2 tons.
You'll go 5 times faster and still generate 760 Lbs of thrust. Mach3 set to a 45kHz kernel speed will get you 1,350 RPM on the motor or a decent 270 IPM.
Mariss
Old 05-09-2009, 02:25 PM
vintageracer's Avatar
vintageracer is on a distinguished road
My Dyna Myte 4400 has the same set up. 200 step 160oz/in steppers, 5:1 pulley ratio and 5mm ball screws. That works out to 50800 steps per inch. I've installed a Gecko G540 and Mach3. At 45kHz kernel speed rapids are 53ipm and at 60kHz kernel speed it can go 70ipm but it tends to fault once in a while so I set it down to 45kHz again.
I have to run some sort of pulley system because the stepper housing is also the ball screw support, so it has to stay. I just wanted to get the mill up and running so I decided to stay with the 5:1 rather than try to search for replacement pulleys.
The G540 runs flawlessly. What an awesome product.
I must admit though, I can cut 0.750" deep with a 0.750" two flute cutter at 12ipm and the machine doesn't even flinch.
Timothy
Old 05-13-2009, 08:39 AM
Jeff-Birt's Avatar
Jeff-Birt is on a distinguished road
Most steppers are mounted direct drive because people don't know any better or they are just lazy. There are even a few direct drive servo systems out there!
Small machines like the Taig and Sherline use a 20 pitch lead screw so there is enough reduction built in to use a direct drive. With a lower pitch screw like you will find in most other machines you really need some sort of reduction. Now depending on the power band of your motor/driver combination 5:1 may be a bit high. The goal, IMHO, is to have the motor have the most power available in the speed range you will be cutting at. For the most part 100 IPM rapids on small machines are pointless and only serve to wear things out faster.
Servos produce their power at higher RPMs and need more reduction than a similar stepper driven system.
Jeff Birt
Old 05-13-2009, 02:22 PM
HRW-MASTER's Avatar
HRW-MASTER is on a distinguished road
Post
Poppycock.
They are mounted that way because they do not need any more reduction.
Hank
  #11   Ban this user!
Old 05-13-2009, 04:08 PM
Jeff-Birt's Avatar
Sorry, not to argue and get way off topic, but that is just not the case. It is like trying to start out in the 3rd gear of a five speed transmission. It is why folks have tendency to mount huge 1000 oz-in motors on a little X3, they are trying to drive a 5 pitch screw with no reduction.
Jeff Birt
  #12   Ban this user!
Old 05-13-2009, 08:09 PM
HRW-MASTER's Avatar
Question
Jeff-Birt,
If the ball screw is the correct TPI or pitch then mounting a stepper directly to ballscrew is perfectly acceptable and the prefered choice.
Are you implying THK, NSK, and many other state of the art manufacturer's are lazy?
You must be joking right?
Hank
Diseno de la Tarjeta Controladora Micro-Step Unipolar "Mardus-Kreutz" kreutz Spanish CNCzone 266 Yesterday 04:45 PM
Controladora Micro-step para 4 ejes. Tipo Bipolar, de 48 volts 5 Amperes kreutz Spanish CNCzone 160 07-25-2010 02:13 PM
NEW! 4D H2 PCB CNC Controller (Micro-Step)! icm Product Announcements & Manufacturer News 0 04-22-2009 10:55 AM
I can't get my keling 387oz-in motors to step evenly with my G540 codevark Gecko Drives 0 03-16-2009 11:32 PM
Need Help!- How to edit MPFAN post file step by step m_bhui Post Processors for MC 2 10-04-2008 05:42 AM
