Old 06-02-2003, 10:15 PM
balsaman's Avatar
balsaman is on a distinguished road
gecko servo steps
How do you set up the software for the resolution of your system with gecko320's. Is it one step per pulse of the encoder you use?
What is the best PPR encoder to use? 300, 600, 1800?
If I use 1800 PPR encoders can I set the software up that 1 step = 3 pulses from the encoder? I wouldn't need such fine resolution.
Eric
I wish it wouldn't crash.
Old 06-19-2003, 02:07 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
A G320 will multiply the CPR of an encoder by 4 times. So if you have a 250 CPR encoder it will take 1000 pulses to turn the motor one full turn.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 06-19-2003, 02:39 PM
balsaman's Avatar
Is that multipier fixed in the gecko or is it user selectable via jumpers or something.
I have 2, 300 PPR encoders and 1, 1800 PPR encoder.
Eric
Old 06-19-2003, 04:00 PM
HomeCNC's Avatar
The G320 is fixed. The G340 I think has some way to change this value but I have not ever used a G340.
Old 06-20-2003, 12:27 AM
balsaman's Avatar
Ok thanks Jeff. I looked again and all my encoders are 300 PPR.
I hope they will work. I also home my P166MMX can dish out that may pulses....
Eric
What is the standard overshot for a servo? InsaneEPP Servo Motors and Drives 17 11-01-2004 01:19 PM
Help! Consistent Gecko Fault or Servo Stall Noah Gecko Drives 11 06-30-2004 11:48 AM
Servos or Steppers..... and other gecko related questions UKRobotics Gecko Drives 11 04-19-2004 03:14 PM
Servo on Taig with Gecko Jcadwell Gecko Drives 4 03-09-2004 12:13 AM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 09:42 PM
