Hello, Im needing some help. I have 4 Gecko G320's running 4 Servos. The power supply I am using is the Keling 65V 20A. Servos are rated 72V 12A max. I tried to follow the DC Brush type Servo diagram posted on Gecko Drives website https://www.geckodrive.com/upload/El...nicalEStop.pdf Everything works correctly, estop cuts AC power to the power supply, But im not sure if I have the wiring right for the "Load Dump Resistor" I have a 25w 8.2ohm resistor that is connected to the NC side of my DPDT 120v relay. When power is cut by estop the relay connects the resistor to the +DC and -DC side of my power supply. I tried this a few times, then noticed a spark in the relay and upon closer inspection the relay contacts have melted!! ![]() With the resistor disconnected everything works fine, but the servo would hold position for about 30 secs after power was removed, then the Gecko would let out a quiet high pitched whine and quickly stopped. Can someone help me with the resistor, i think I have it connected wrong.. Next problem, are my ground connections. Im a little confused as to what is "Earth Ground" and what isnt. I dont have anything but the electronics enclosure case and the servo ground connected to AC earth ground. Am i supposed to connect all the -DC to ground aswell? Where does the gecko get its -DC power from? I have the common pin on the G320 connected to +5V Last problem, I did a bench test and had a servo turning from MACH3, I have since built my enclosure and I redid all my wiring, but I cant get the G320s to turn on, I dont seem to be getting +5v Power to them. With motor and encoder connected the G320 does nothing. No fault light. With encoder disconnected motor will turn at a constant speed. G320 has its DC+,DC- and its +5v connected and the motor and encoder connected. It also has Err/Res jumpered to ENC+ Im sure im missing something, if anyone can clear up some of my questions that would be great. Im not very experienced with electronics but I learn very quickly. And help would be greatly appeiciated! |
Make sure your relay has at least 15amp contacts like the gecko document suggests and I would go for a heavier relay if possible. Also remember that this is an E-STOP circuit and not a day in and day out contact. The relay is under a lot of stress because of what you are doing to it and it will take a beating. It will work great but I don't think it will survive hundreds of contacts when switching in this application, but I could be wrong. I think the contacts will initially see power supply voltage which is 65v dc in your case. Make sure the contacts are rated for this kind of dc voltage. The drive ground is on Pin 1 and comes from the dc power supply negative terminal. I would open the gecko manual and go thru all of the setup steps again. It is very easy to make a wiring mistake. I would also do the ohm meter check listed on the gecko site to determine if you have cooked a drive. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| ok, so I will check the rating on the contact, I was pretty sure it was rated to handle 15A. The pin 1 im assuming you mean is the high power (65V DC) ground, Does the +5V get its ground from the same place as the +65V? This whole grounding this is confusing me. Can someone clear up what it "Earth ground" and whats just a Ground return? Do i want to connect both the -65V and the -5V to "Earth Ground" I think my problem is in the grounding, 5v is not reaching the Geckos.
| As pointed out in this article that unfortunately the term ground has become to be used for any supply common regardless of whether it is at earth ground or not. If using the term Ground without reference to the supply it is relative to, creates misunderstanding. http://www.ese.upenn.edu/rca/instrum...round/grd.html Al.
You have +5v hooked up to the common terminal. The negative part of this comes from the step and direction signals. If I remember correctly the case of the gecko drive is at ground potential which is connected thru the enclosure to earth ground. When you say -65v you are incorrect as far as the gecko is concerned. There is +65v and 0v, not +65v and -65v. Mike
regardless im gonna go read that link on grounding.. |
| Re your bleed down resistor, I have the same issue. I'm going to try a larger value resister to try and lower the current during drain. I'm using a 30 Amp contact relay, and it still looks like a welding machine in my enclosure. Re your grounding issues, I had the same issue as well. I've since tied all my power supply grounds to the chasis. No more issues. |
Thanks for your reply, Im glad someone else is having trouble with that resistor estop system. An electrician friend of mine asked if I was using DC rated contacts in the relay and When i looked it didnt say DC anywhere on it.. Im going to look for DC rated contacts, but if i cant find it I will probably do what you mentioned and go with a higher value resistor.. what do you think would be a good value to go for? And I am going to chassis ground the - side of all DC supplies.. I noticed the 5V was already chassis grounded when connected to the BOB. But that brings up another question... Do the Geckos need to have their case chassis grounded? I got them mounted on heatsinks and the heatsinks are just hot glued to the case, no real chassis connection there, but I dont think that the Geckos can get a connection through the anodizing? anyone know for sure? |
| As far as I know, the G320 is grounded through the Power Ground terminal, not the chasis of the drive. (I could be mistaken though) I'm not sure what value to use for the bleed down. I'm just going to try somthing that will bleed at about 5 amps rather than the 10 amps that mine is currently at. |
#10
| Phife/Hellpit, did you solve the DC dump circuit melting your relay contacts? I have been fighting this same thing for two weeks using the same Geckodrive schematic!! I've tried all kinds of things, putting estop on the hot side so no switches on AC common, having one relay just switch another relay and have that relay do the dumping. I still have the same issue. I have 15 amp rated relays. I have tried 3 different relays. I have 7.5 ohm 25 watt wirewound resistors. It burns the NC contacts on the dump circuit, the contacts that should be OPEN when the relay switches!! Impossible. It burns them when the momentary start switch is pressed. Is the big DC voltage not allowing the contacts to open, or is it jumping the contact, or....?? My PS is Keling KL7220, 72 volt 20 amp, but it has 2 outputs so I am using a 3P2T relay to dump the two sides, which I ASSUME are 10 amps each, correct? For 2 weeks, nothing but 3 burnt up relays. I/we need to solve this thing!! I've posted elsewhere with no answers. I thought it was my electrical noob position, but I guess I'm not the only one. I have a pretty competant electrical guy stumped by this, too. And another looking at it next week. What's the solution to this? Last edited by thosj; 05-02-2009 at 10:00 PM. |
#11
| There is a great deal of energy when dumping a large charged capacitor, this is the basis behind steel stud welding. You may want to look at the principle used by VFD's etc for dumping back EMF voltage by switching in a large solid state device like a HexFet. Al.
#12
| No answer yet. My next option is to try a contactor, I am also going to go up to something like 20-40ohm resistor, see if that helps. I too tried the resistor in various arrangements and went through 3 relays. That Estop diagram needs to get updated. Seems alot of people are having this issue. Just waiting for my local electronics store to get some more stock in. I did get the ground and no power figured out, Im connecting all my DC grounds to a separate bus and using chassis and earth ground for actual earth grounding. Also my no power problem was that i had the encoder wired wrong, I was using some CAT5e cable for my encoder wiring and had some crossed wires at the RJ45 breakout. Motors would turn on their own when encoder was disconnected, no faults, no power to enc+ or err/res. Rewired encoders and now everything is good. |
| G320 Power-up Fault | Mariss Freimanis | Gecko Drives | 2 | 11-22-2009 11:33 PM |
| G320 encoder power supply | rbcmetalwork | Gecko Drives | 2 | 02-10-2009 09:41 PM |
| Power supply ground clarification. | Ken_Shea | General Electronics Discussion | 22 | 10-16-2007 09:54 AM |
| g320 servo drive initial testing - problems and questions | fbmstar | Gecko Drives | 2 | 04-09-2007 09:45 PM |
| Power Supply ground question | chas | Gecko Drives | 5 | 04-16-2005 06:48 AM |
