Old 04-23-2009, 08:52 PM
rlrhett is on a distinguished road
Loud Buzz/Whine from motors
I have just wired up my 251's for the first time to some Anaheim Automation 34D209S-LW6 wired in series (red -A, red/white - /A, green -B, green/white -/B, black, white -- taped off). I have a Keling 36v power supply and a C10 break out board.
As soon as I power up the motors begin a loud high pitched buzz/whine. They do not get hot, the drives light up and are only warm to the touch, and the break out board is not hot and has a power light. However, when I try to jog with Mach 3 I get very slow motion, usually in only one direction, and very irregular.
I've done the driver test in Mach 3, and get a good signal. I've also tried tuning the motors in Mach 3, but changing the acceleration or velocity seemed to have only marginal effect. I have disconnected the screw drives so the motors could spin freely. They still barely move.
I've checked the wiring as best as I can and all seems to be correct. Any thoughts?
High Pitched Whine From VFD Driven Motor hamholfarm Phase Converters and VFD 3 07-22-2008 05:55 PM
Hearing saftey- stepper motor PWM whine nullbert Benchtop Machines 1 07-04-2008 08:43 PM
g201's motors buzz, but do not move mxpro32 Gecko Drives 9 09-06-2007 05:25 PM
Motor whine, no rotation flyboy1015 Mach Software (ArtSoft software) 9 03-02-2007 09:32 PM
Whine / squeal noises when machine idle bkraz Bridgeport and Hardinge Mills 5 02-09-2006 05:29 AM
