I've got 4 gecko 203V's driving 4 hobby cnc 425 oz/in steppers. I am using a 56V DC power supply. The steppers get quite warm with the controller on and the steppers not moving. I just ran a program that cut for about 30 minutes and the steppers were hot. I couldn't hold my hand on them for more than 2 seconds. Is this normal? Is there something I can tweak in mach 3 to allow the geckos to drive them cooler? thanks, Brendin |
| I am running them in bipolar parallel and the current set resistor is limiting it to 4.2A. Brendin |
I believe the value was between 63 and 68K. from the manual Here are the current set resistor values for motor current in .5A increments. Round the appropriate answer to the nearest 5% resistor value. a. 1A – 7.8K b. 1.5A – 12.8K c. 2A – 18.8K d. 2.5A – 26.1K e. 3A – 35.25K f. 3.5A – 47K g. 4A – 62.67K h. 4.5A – 84.6K i. 5A – 117.5K j. 5.5A – 172.33K k. 6A – 282K l. 6.5A – 611K m. 7A – OPEN |
Yes...54V measured. I got some responses on another board and these motors run HOT and max temp is 200F. |
#10
| I measured the temp and it was 143F. I was told that the max temp for these is 200F and that I could run them at a lower voltage to reduce the heat and I wouldn't lose that much power. I'll probably make some aluminum mounts to replace the HDPE or perhaps put som heat sinks on them. I am not too worried though as they were well below the max temp. |
| Help, can't get steppers to run ! | SScnc | Mach Software (ArtSoft software) | 15 | 07-05-2008 11:25 AM |
| Different steppers! | GEFR | Hobbycnc (Products) | 1 | 05-01-2008 11:56 AM |
| Using steppers for something else | ChristianW | DIY-CNC Router Table Machines | 1 | 07-20-2007 03:05 AM |
| Steppers | JBV | Benchtop Machines | 4 | 09-16-2005 01:13 PM |
| 3 Steppers? | drakesis | Stepper Motors and Drives | 4 | 06-14-2005 12:40 PM |
