Old 01-16-2005, 07:39 PM
SimonSays is on a distinguished road
Resister Help Gecko Newbie
I have just purchased the Gecko 201 and need to figure out the proper resiter.
I have Vexta PH 299-O1 2 Phase 3V 4amp steppers
Do I just put a 62 K resister on the Term 11 and 12 and if so how acurate does the resister have to be I went to my local radio shack and they dont have a 62K but the store clerk said I could solder multiple ones together to get 62K.
Thank you for your help
Simonsays/West Michigan
Old 01-16-2005, 08:56 PM
trubleshtr is on a distinguished road
Is the 62k a rating from gecko to use with their drive? I am assuming they are to be used with the encoder set-up as terminating resisters? If so, then I would just stick with their recommendation.
Or are you trying to calculate resistance for some other reason?
menomana
Old 01-16-2005, 10:47 PM
Gold Member
JFettig is on a distinguished road
If you can find something close to it, it would do fine, otherwize if you want 62k by putting them together, they must be in series, in parallel they will have less resistance.
Jon
Old 01-17-2005, 09:59 AM
Al_The_Man's Avatar
If they have these values they can be used either in series or parallel to get 62k, depending on what they have e.g. 2x 30k or 33k in series or 2x 127k in parallel.
Al
Old 01-18-2005, 10:46 AM
Thank you for the help
Thanks again for the help I'll be back with more Questions
once I get them mounted in my electrical encloser.
Simonsays/West MI
Newbie questions gecko drive limit ? Calico Gecko Drives 0 04-03-2005 05:15 AM
Gecko 320's startup for the newbie? DaSigntist Gecko Drives 15 03-14-2005 08:09 PM
Gecko vs Rutex samualt Gecko Drives 20 10-21-2004 01:48 AM
Servos or Steppers..... and other gecko related questions UKRobotics Gecko Drives 11 04-19-2004 02:14 PM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 08:42 PM
