Hi, I have a g540 with a 48V power supply and 269oz steppers. I am running EMC2 and I need setup HELP! I have the controller hooked up to an e-stop and 1 stepper. I hooked the 540 up to my computer using my EMC2 Xylotex .ini file ...just changing the steps per inch to 40000. The problem that I'm having is: I drive the stepper for a little bit and it stalls giving me a Joint 0 following error. I've tried speeding up and slowing down the IPM as well as slowing down the acceleration. No matter what It only jogs a little bit and then stalls. Just an FYI the stepper is not hooked up to my mill. Thanks, Frank |
| I was just playing with the controller setup the way it is and I was able to get the motor running at 10IPM with out error. Pretty much any faster than that and it gives the error. the faster the speed is set the faster it stalls. If the speed is a around 14IPM it will sometimes run fine but stall and error out when you let off. I tried messing with the accel some more and I even turned it down to .5 still didn't change anything. Is the problem my computer? My mill was able to run 17-18IPM on one of its axes with my 24V Xylotex controller. I'm confused. ...I'm really just looking to be able to rapid at around 30-50IPM...no less than 20IPM. |
| How many threads to the inch are you using for screws? Also another thought, what is your base period and your latency? How many steps per inch were you using on your Xylotex? Alan
__________________ http://www.alansmachineworks.com |
| Im not sure what exactly latency or base period are. I did do a latency test yesterday and my max jitter(that's what it said was important) was like 15000. The motor isn't turning anything right now I don't have it hooked up to a lead screw. The IPM's are based on a 1/4 - 20 lead screw (taig mill). My Xylotex was running like 10IPM on the z & 15-18 on the X & Y. Those were my rapid speeds. |
Is 40000 a typo, my misunderstanding or a problem? It seems to me like 400 steps per revolution on the stepper x 10 revolutions per inch on the machine axis should be 4000 steps per inch, not 40000. This would fit with stalling at speeds lower than expected. BobH |
#10
| BobH |
#11
| Alan
__________________ http://www.alansmachineworks.com Last edited by acondit; 04-08-2009 at 04:45 PM. |
#12
The base period is recorded in the .ini file. For example, with your screw and 10 microstepping; BASE_PERIOD = 50,000 gives a theoretical 15 ipm 25,000 = 30 ipm 15,000 = 50 ipm At least I think that's right. Emc evolves quickly and there's some double-step thingy I still don't quite grasp. And then there's Gecko's morphing trickery that might also have some effect ? And of course you can't demand a base period beyond the computers capabilities. Man this stuff gets confusing ! If BASE_PERIOD is a high number (like 50,000) you could try lowering the setting until the computer starts to bog. I'm guessing however you have it set considerably lower. Maybe try running stepconf again using Gecko's timing specs ? Just plugging a new scale into an existing Xylotex .ini seems like asking for trouble ![]() You could also ask on the emc-user-mailinglist. There's been some testing with the g540.
__________________ Anyone who says "It only goes together one way" has no imagination. |
| g540 | Scooby Doo | Gecko Drives | 62 | 05-17-2009 01:44 PM |
| g540 and over-voltage | draughted | Gecko Drives | 32 | 02-05-2009 01:55 AM |
| can you... BOB to G540? | Fixittt | Gecko Drives | 7 | 01-28-2009 06:37 AM |
| G540 - WOW! | LaserImage | Gecko Drives | 6 | 12-04-2008 03:30 PM |
| Newbie- Sieg X1 retrofit with Linux EMC2, CNC Fusion retrofit kit and Gecko G540 | GreenLead | Benchtop Machines | 31 | 11-26-2008 11:55 PM |
