Old 04-07-2009, 03:20 PM
radioactive is on a distinguished road
G320 - reversing default motor direction
If my servo's turn the wrong way, I know I can do as the Gecko manual says and swap the encoder A & B leads and the motor + and - leads but couldn't I also just make a change in Mach3 for the Direction output (select Active low instead of active high)?
Supermax YCM-40 Mill, Mach3, G320's, RogersMachine, PMDX-122 ---- Slowly coming up to speed... (that's me, not the machine)
reversing homing direction without inverting axis? draughted LinuxCNC (formerly EMC2) 10 04-08-2009 04:04 AM
Need Help!- reversing display direction barnesy Mach Mill 10 12-17-2008 09:47 PM
G320/G340 'Required Direction Setup' and 'Required Direction Hold' times? margni74 Gecko Drives 2 12-05-2008 08:10 PM
possibly ignorant question about acceleration... also reversing direction jvanick LinuxCNC (formerly EMC2) 11 09-16-2008 11:18 AM
reversing a ac servo motor 69owb Servo Motors and Drives 9 09-02-2007 08:49 AM
