Old 04-05-2009, 10:55 PM
meck11 is on a distinguished road
gecko 540 with mach3
using kelling 387 motors with mach 3 and gecko
any help would be apreciated 1:13 lead screw
currently runiing 26000 steps 20 velocity 2 acceleration
iam not sure if thease are correct velocity acceleration step
Old 04-06-2009, 12:13 AM
TOTALLYRC is on a distinguished road
If you mean a 13tpi lead screw directly driven from the stepper motor,
then you are correct. 26,000 steps per inch with the G540 which is a ten micro step drive. Velocity is what ever you are comfortable with up to the point that the stepper will stall, at which point you back off 10% to be safe. I would say that your acceleration is a little low, but it depends on what you are trying to drive and what results that you are looking for. You will really need to do some trial and error on your machine to make sure it does what you want.
Mike
Old 04-06-2009, 08:19 AM
re velocity
whats a good starting point for velocity will be cutiing mdf
also what should the other values in motor tuning be set
thanks
Old 04-06-2009, 08:34 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Velocity setting has nothing to do with what you are cutting. THAT is controlled by F feed rate. Are you using the G540B xml file downloaded from Gecko?
CR.
Old 04-06-2009, 08:43 AM
g540
yes
how does one change feed rate
is that locked be cad software
Old 04-06-2009, 08:53 AM
Feed rate is set either directly in G code, or in CAM software.
Check this out:
http://www.cnczone.com/forums/showthread.php?t=76865.#3
CR.
Gecko Faulting and Mach3 lifestill Mach Mill 8 07-02-2009 12:34 AM
Mach3 Gecko 201 Ed Williams Gecko Drives 7 08-20-2008 12:16 AM
Mach3 and Gecko G100 johnd Mach Wizards, Macros, & Addons 8 08-17-2008 03:20 AM
Gecko G201 & Mach3 szynszyl Gecko Drives 0 04-10-2007 05:11 PM
