Page 1 of 3 123 LastLast
Results 1 to 12 of 34
Thread: blew a G320??? Don't know why????
    Registered mc-motorsports's Avatar
    Feb 2007
    Bridgeprort retrofit, Mach 3 controller, 20a 48v transformer, 3 servo's and 3 G320's.
    I was cutting out a broken tap using a carbide endmill, I set the jog rate to .7ipm because I was trying to save the part, more or less just trying to grind out the tap and save the threads.
    Well, the servo tripped, I reset it, tried again, it tripped again, I reset it again, one more time and then NOTHING... The Z axis won't move. I can reset the servo's and the X and Y work fine, but the Z won't move.
    The other wierd thing is when I power up the power supply, the servo's automatically engage???
    I'm 99% sure it's the drive because if I disconnect the encodor, the servo does not try to run away, there is still no movement. And with the servo and encodor disconnected, the other two drives engage and disengage fine.
    So did I blow the servo drive running too much amperage on a servo at too slow of a speed? I've been using the servo's and drives with absolutely no problem for 18 months. Or is that just the life expectancy of the servo drive? I use the machine atleast 40 hours a week every week, no problems.
    And I did try the Z axis servo and encodor on the X axis drive and the quill works fine.
    Was it a freak thing? Did I move the servo too slow at max amperage? Or was it just the life expectancy?
    I did order 2 new drives, one to replace the bad drive and another for a back-up from Gecko Drive, ordered at the last minute and they still over-night shipped it! Have to love thier customer service!
    MC
    Dec 2006
    First guess would be yes, to much mojo going on at to slow a speed. Thats really loading things doing that with a servo system, you add the heavy weight of the head and it gets worse.
    Of course there is always the chance of it just being a freak thing that the drive blow. ALso I would keep a eye on that servo because if it has a internal short thats trying to start acting up you might have problems again.
    One thing I have always thought everyone should do is run temp reading equipment on the drives so you can see if things are getting in a strain. The drive will get hot if so. ALso some are using amp meters to help watch things.
    All you can do is chaulk it up to gone for now and keep a eye on things. Be sure you use good thermal paste on the back side of the drive and good air flow/cooling for them. At 48v you would think you would not be pushing the drives that hard but its the amps that can get you the most and on a Bridgeport that can load things pretty quick. I plan to put temp reading equipment on each of my drives and maybe even amp meters. I am a little shy on the amp meters because of some info I was reading that was trying to claim it being a bad thing to put them in line but I feel like one with a good heavy shunt would be no problem. It would be pretty easy to build a little system that keep a eye on the temp with a PIC and some thermisters. It could even be setup to give warning signal or possibly even cause a fault or E-Stop if done right.
    Make sure the wiring didn't take a hit and now has a lot of resistance built up in it. This could be worse than a bad motor. Connectors and power supply itself should be looked at close. Hopefully it was just a freak or a overload. The overload is something you see people do every now and then so I would guess that being the case. The servos like to run in the RPM not at low load. In fact any quick load that stops a servo is a bad thing and should be avoided.
    Jess
    Feb 2007
    Back up and running! I ordered the drives at 6pm EST and they were here at 12pm EST the next day, up and running again by 1pm. Thanks Gecko!
    Feb 2007
    NEVERMIND!!! I just blew another drive!!!
    how do I figure out if it's the servo or the encodor?
    Please help!
    Jan 2006
    It sounds to me like you are overloading the drive too quickly and blowing the MOSFETs.
    Mariss has said that the drive will die if you drive the machine into a brick wall. If you hit a hard stop, the drive does not have time to fold back the current to protect the power stage because the current rises to stall current (maybe 100A or more) almost instantaneously. A carbide endmill into a tap is pretty much a brick wall. It survives the first few times (when drive faults) then it finally gives up.
    I would say .7ipm is too fast. Try something like .1 or as slow as mach will go. If I were you I would use the knee crank to advance it and leave the quill where it is. Also if you could find some way to lock the quill so the servo wasn't taking the load it would help. Go nice and easy.
    Matt
    Feb 2007
    Yes, I've done this many times, but I usually use the knee to feed the endmill, why I used the CNC to drive the quill, I don't know... Never thought it would be a problem, guess I got lazy last time.
    But the problem is not the drive, I just blew another drive and I wasn't doing anything dumb this time, running the same programs I run every day and the new drive failed within 20 minutes. Telling me either the servo or the encodor was damaged or went bad. I just ordered another servo and encodor, I don't know which is bad, I'll just replace them both.
    MC
    Jan 2006
    I don't think any problem with the encoder would kill the drive. Unless it somehow pumped excess voltage into the logic or its shorting the encoder supply.
    Good Luck
    Matt
    Feb 2007
    I know almost nothing about DC brush servo's. The old servo measures 1.5 ohm static, no load, no RPM, and resistance goes up and changes with RPM, spinning by hand. The new servo does the same thing, so I'm gussing the servo is ok?
    Pole to ground is infinate on a 20m scale, I only have a cheap VOM, I don't have access to a surge tester any more, anything else I can check? Probably not with only a VOM?
    I'm replacing the drive, the servo and the encodor, hoping to solve the problem, there is no binding in the z axis, moves freely turning the ballscrew by hand. But I still don't have a definate answer on where the problem is or was...
    Feb 2007
    I GIVE UP! I just blew another drive.... Works fine on the Y axis drive, works fine on the X axis drive, just swapped the encodor and power cables. I just burned up 2 brand new drives and I have no clue why. I checked all of the wiring, made sure every terminal was tight. I don't know what to do...................
    Dec 2004
    Quote Originally Posted by mc-motorsports View Post
    MC
    Well if this is a change from the way it used to work, then it could be the culprit.
    From your last post, it all works well on the x and y, but not the z axis.
    I would check for continuity form the z motor wire to ground and each other when shaking the wires. sounds like you have a short between the 2 power wires or to ground. both of these will blow a drive almost imediately.
    It would only take one stand of copper wire inside a connector or something stupid like that to pop the drive.
    Mike
    I would also consider talking directly with gecko for more suggestions before you blow anything else.
    Feb 2007
    I can just unplug the power cable and encodor cable and plug it into the X or Y axis and it works fine. And yes, I did check the wiring, a visual of the outside looking for breaks or anything, and also checked it with a VOM before wiring in the new servo, everthing checked fine.
    It's not the wiring, it's not the servo, it's not the encodor.......
    BOB?
    I don't know...
    I'm ready to **** can everything and start over with brand new everything. I'm losing a lot of money and it's hard to just keep buying new parts when you have to turn away work.
    Feb 2007
    One other thing that is weird and I don't understand. If the servo loses position, the drives don't fault??? I've had a couple of instances in the past where I did something dumb and plowed a tool into a part, and the servo would fault immediatly. I still have a feed handle on one side of the x axis, if you fight the servo and turn the handle, it does not fault out??????????
    What the hell happened? Everything was working fine and now everything went to hell??? Dead serious this machine runs 40+ hours a week, has been for 18 months without 1 single problem, then the other day, everything just went to ****???????
    I REALLY don't get it.
    ANY help or advice is appreciated!
  • Page 1 of 3 123 LastLast
    1. Need Help!- Blew up my controller! :(
      By Redbeard5 in forum Wood Lathes / Mills
      Last Post: 05-30-2008, 06:05 AM
    2. what blew up?
      By cyclestart in forum Controller & Computer Solutions
      Last Post: 02-27-2008, 07:43 AM
    3. Please help I blew up an IC on syil x3
      By Nicodemus in forum Syil Products
      Last Post: 03-14-2007, 02:20 PM
    4. Blew up my original 5C
      By BennettPrescott in forum Haas Mills
      Last Post: 11-20-2005, 10:07 PM
