| Debetto, The PMDX-122 is buffered, so you dont need to worry. This is posted on the PMDX.COM website The PMDX-122 is a motion control breakout board for interfacing with the parallel port of an IBM-PC style computer +Supports all signals present on a standard printer port. (8 data, 5 input, 4 output) +Allows the 8 bit data port to be used as outputs (step/dir/etc) or as 8 input bits. +Great for second parallel port usage when using encoders or lots of feedback signals. +Buffers signals to protect the PC's printer port. +Utilizes standard IEEE-1284 Centronics style printer cable for connection to PC. +Connection to PC can also be via a 26 pin ribbon cable which allows a remote DB-25 to be used. +Provides LED status indicators on all 8 data port signals, 5 input and 4 output signals. +Supports the MACH "charge pump" signal to inhibit outputs when the MACH software is not running. +The "charge pump" function can be daisy chained between boards +Inhibits outputs when E-Stop or Fault inputs are asserted. +Reports E-Stop to computer on loss of power, E-Stop loop open, Fault input grounded, or printer cable disconnected +Provides one 10 Amp. relay on board for spindle or other I/O output function. +Inputs have pull-ups to +5 volts and are filtered to suppress noise. +Step and direction outputs from data bits can be common ground or common +5 volts for driving opto inputs. +All I/O connections are made via wire clamp screw terminal strips. +Auxiliary +5 volt DC output available to power sensors. +Three power supply options. (external DC, external AC, or USB port power steal) +LED to indicate "outputs enabled" status so "charge pump" status can be seen. +Jumpers to control "charge pump" functionality, E-Stop behavior, and data port direction The PMDX-122 and G251 combo will work fine. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| The Lack Of The One Program To Do It All And Do It Right | berin | OpenSource Software | 7 | 01-15-2007 12:15 AM |
| Spindle speed range or lack of it! | creep_pea | Bridgeport and Hardinge Mills | 7 | 10-04-2006 04:42 PM |
| Major lack of torque with steppers | curtisturner | Stepper Motors and Drives | 16 | 07-05-2006 09:26 AM |
| Complete Lack of Experience | rcazwillis | General Metalwork Discussion | 6 | 12-04-2005 08:48 PM |
| PICStep and the lack of updates! | Garfield2 | PicStep Controllers | 2 | 05-21-2005 05:00 AM |
