Hi, Can someone explain to me how the G540 knows to micro-step. I have read both manuals on the Gecko site and it only states that "Four 10-microstep motor drives", which implies that the motor needs to be capable of micro-stepping. I am trying to setup my X-axis which is a belt drive unit in Mach 3. Here's my maths: Pulley 75mm diameter Motor 200 steps/rev 75 X 2 pie => 1 Step is 0.5890mm or 43.11 SPI So in Mach 3 I can set 43.11, but that gives me bad resolution. What do I need to do next to get this working. PS: Why do i need to set imperial setting in Mach 3 when my global setup states that I am working in mm? I have checked my travel on a vernier and it outputs close to Mach 3 DRO output. Thanks in advance /Michael |
| When using the Geckos, it's 2000 steps/rev. (200 x 10 microsteps). Also, circumference would be 75 x pi, (2 x pi x r, or pi x d)
| Yes your right my mistake with the formula. I forgot to mention i'm running 4:1 reduction on the belt drive Okay so what I have is: 1 step = (2 X 3.142 X 75)/200 = 471.2385 / 200 = 2.3561925 mm/step or 1 step = 25.4 / 2.3561925 = 10.78 SPI Therefore given your statement, the G540 is automatically using micro-stepping and i should set: 107.8 X 4 = 431.20 steps in Mach 3 for the X-axis? (which is incidentally what I had above) Other questions: 2. The G540 manual does not state that a cap is required on the motor supply, unlike the G201 manual. Does this imply that one is not required? I have an un-regulated 50Vdc supply) 3. I have wired my 8 wire stepper in series. I just read that half the current will be used, so given my rates output is 2 Amps, I should use a 1K resistor for these motors. (Just checking with this question) 4. Series V's parallel : I just read the Gecko step motor basics pdf and it explains the voltage/current relationship, but can someone please explain application advantages for this. I have a gantry router which is for personal use. I run a 50Vdc supply. /M Last edited by mikie; 03-15-2009 at 10:56 PM. |
| The geckos microstep in 10 divisions so we get 0.18 degrees/rev for each step with standard 1.8degree steppers. Nice. What's even better, is the geckos will gradually switch to full stepping mode when the steppers are going fast. This is the best of both worlds. We microstep to get better resolution at the cost of torque output. We full step for greater torque. Unlike the cheap motor drivers geckos do both modes automatically. Our signals to the motors dont change though, we send 2000 pulses/rev no matter what. Use parallel wiring for the greatest torque from the steppers. Serial wiring will save you power but at the cost of torque. Your decision, if you dont need the extra torque you could use serial wiring. With serial you can double the voltage to get more power out of them but you still wont get the power of parallel wiring due. Do you have 6 or 8 wire motors? I dont really get your math. With a 4:1 reduction using a pulley, then you have 200*10*4 = 8000 pulses/rev at the big pulley. So do you have a leadscrew the pulley is driving? What is the threads/inch? (or mm/rev?) |
| Thanks for the reply. Clarified it beautifully. The pulley is driving a belt which connects to the gantry. (No lead-screw on my x-axis) I run an 8 wire stepper, so after doing the math with the serial and parallel setup and knowing that the G540 only accepts 50Vdc, which is what i am running on my transformer output i will stick with my serial setup. Here is a picture of the router: |
You want parallel, not serial. Parallel runs much faster than serial at any given voltage, and only needs half the serial voltage for max performance. Are the motors rated 2 amps parallel, or serial?
| Let's see if I get this right. With your 4:1 reduction, 4 turns of your motor gives you 75 x pi of movement, or 235.619mm/ Divided by 4, you get 58.9048 mm per rev. With 2000 steps per rev (200 x 10 microsteps, you get 33.953 steps/mm.
| Gerry, Here is the spec sheet with limited info: Sorry about the clarity, but this is best I could do with my scanner. That is quite poor resolution really. Mmm might have to get rid of the belt and re-fit with screws. |
#10
| With steppers, there's a dilemma that you can't get around. The faster you want to go, the lower the resolution you'll have to live with. Right now, you have about .03mm /step. If you're machine can hold that tolerance, that's not bad for cutting wood. That sheet doesn't tell you if it's rated serial or parallel. You can check the resistance with a meter and figure out which it is.
#11
| Forgot to say to double check my numbers and make sure they're right.
| Tags |
| g540, mach3, microstep |
| unipolar motor microstepping | mardus | Stepper Motors and Drives | 495 | 09-18-2011 04:03 AM |
| G540 Stepper motor spec | tumutbound | Gecko Drives | 32 | 03-08-2009 11:20 AM |
| Need Help!- g540 setup question | don_don | Gecko Drives | 17 | 02-16-2009 02:05 PM |
| New Machine Build- Gecko G540 and Motor mH rating | ronateah | Gecko Drives | 3 | 11-18-2008 10:05 AM |
| NEW Arcsin microstepping motor driver | cnc2k | Stepper Motors and Drives | 2 | 04-29-2005 10:13 PM |
