I am having problems getting my g540 to come out of fault with the charge pump switch active. All my motors run fine, estop works great when switch is turned off inside the g540 I turn the switch on. I get a fault. got the charge pump port/pin set to port 1 and pin 16 like the set up guide said with no luck I have estop wired to port 1 pin 15 works fine (with switch turned off) With the charge pump active i get a fault and a external estop i cant reset?
__________________ Nick I Know I Cant Spell..Don't Remind Me |
I'm still researching it, I think i did see two different ways to wire it. |
| Are there different BOB in the g540? The wire diagram i read just show pin 10 to estop to ground or pin 12 on the gecko.(Pins on front of gekco unit) And charge pump at port im using (port 1) pin 16. (pin in db25 parallel)
| Finishlinewrx, Are you loading the G540.xml file? Is your parallel port set to EPP in your computer bios? Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| The parallel is a add on pci card. it says epp compatable. There is no option to change in bios since there is no onboard port.
| If you use the xml file you will have to change the port address if you use the add on PCI card. To find out what the port address is go to Start>control panel>system>hardware>device mamager>comm/lpt ports>resources Dan Mauch www.camtronics-cnc.com low cost cases for the G540 |
| i have the same problem my g540 works fine when using built in motherboard lpt. i cant get it to work with pci lpt added cart. i changed adresses and i can see with voltmeter it gives signals dir and step and charge pump is 2.5 volts and 0volts when chargepump is off, but gecko doesnt turn on. with xylotex board added pci lpt card works fine. |
| I've got the same problem; - DB25 straight thru cable - EPP compatible PCI card with latest mfg driver file (Rosewill RC-304) - Port address is correct in Mach3 - G540 in Keling box (pre-wired) - xml file from Gecko (pump on port #1, pin 16. Watchdogs yes and pump on e-stop) - Mach3 - I don't have an option for EPP in the Device Manager anywhere Whenever I enable the charge pump I cannot get out of fault mode. When I disable the charge pump I get a green light and the motors will turn. Anyone with a PCI add-on parallel card that can get the charge pump to work with a G540 and Mach3? If so, what card and was EPP an option in Device Manager? Any other ideas? |
#10
My Creative I/O PCI Multi I/O Controller card shows up in Device Manager as LPT3, starting addresses DC00 and D880. It is communicating with my C11G to display status in Mach3 Diagnostics screen. I have not tried to change the mode since it is working. I just now looked in the installation CD folder for the MosChip MCS9865 device driver that is on the I/O card and there is a PDF file that says that this chip automatically sets the parallel port mode by handshaking with the device that it is connected to. Edit: If you uninstall then reinstall the driver for your parallel port I/O card you should then get a chance to change mode assignments manually even if your card uses auto-configuration. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). Last edited by CarveOne; 12-19-2009 at 06:00 AM. Reason: Add new info |
#11
| Hi, You may find that is a config setting in Mach3. Check and see that you have the "ChargePump On in EStop" checkbox ticked in the Mach3 General Config settings tab. Cheers, Peter.
__________________ ------------------------------------------------- Homann Designs - http://www.homanndesigns.com |
| Charge Pump | cadmonkey | LinuxCNC (formerly EMC2) | 8 | 04-06-2010 01:19 AM |
| charge pump | eloid | DIY-CNC Router Table Machines | 3 | 01-25-2009 09:14 AM |
| Charge pump for Hilbilly BOB | dougputt | Mach Software (ArtSoft software) | 2 | 10-11-2007 12:31 PM |
| Charge Pump ??? | jack55 | General Electronics Discussion | 6 | 04-21-2007 02:59 PM |
| Charge pump | mlaws1172 | Screen Layouts, Post Processors & Misc | 0 | 01-03-2006 10:46 PM |
