Old 03-06-2009, 06:49 PM
Gold Member
Mariss Freimanis is on a distinguished road
G380 Sneak Peek
The G380 board gerbers went out for fast-turn prototype boards. I generated a rendering of what the finished drive will look like using those boards. It looked cool so I thought I'd share the picture.
Mariss
Old 03-15-2009, 08:31 PM
guru_florida's Avatar
guru_florida is on a distinguished road
I'm curious. What EDA software do you use? I'm going to take a guess at Altium DXP?
Old 03-15-2009, 09:19 PM
the4thseal is on a distinguished road
so when do you think we can get this?
Old 03-15-2009, 09:48 PM
Gold Member
Considering the CPLD is a Xylinx CoolRunnerII I'm using Xylinx's ISE development software. For everything else I use ACAD2000 (schematics, board layout, 3D modeling, etc.).
Mariss
Old 03-17-2009, 10:53 PM
TOTALLYRC is on a distinguished road
Looking good.
It looks like another winner from the stable of Gecko drive.
At one point, IIRC, you were considering offering an analog version of this drive.
If so, would it be sooner rather than later and can the drive be set to no pid since the pid is done in my dspmc/ip controller. I don't know if having pid inside pid would pose any problems.
Mike
Old 03-19-2009, 01:10 PM
Gold Member
Here is a scope picture of how the G380 reacts to an encoder failure or disconnect. The motor is turning at 3,000 RPM when the encoder CH_A (yellow trace) is disconnected.
The motor is dynamically braked at the CURRENT LIMIT set value, 12A in this case (green trace). Note the 'flat' current at 12A. The motor brakes to a stop 0.08 seconds later. The G380 FAULT LED lights immediately on encoder disconnect and stays lit until the encoder connection is restored.
Mariss
Name:	ENCODER FAIL.gif‎
Old 03-19-2009, 01:52 PM
Nice to see encoder detection being implemented.
What happens at very slow speed or at rest and the encoder is either disconnected or dies?
I know that perfect encoder failure detection not that easy, but it is nice too see that you are working on it. It also doesn't hurt to dream.
Mike
Old 03-19-2009, 02:06 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Just a suggestion, and I'm probably not the only one who thinks this, but why do you use such small terminal blocks? They are a PITA to work with 'in the real world'.
I doubt size of the unit is a big consideration for most people who buy your products.
Just my opinion.
Paul
Old 03-19-2009, 02:23 PM
Gold Member
The encoder fail detect senses illegal voltages on the encoder inputs (1V > illegal > 3V) using window comparators on both encoder channels. This is both a static as well as dynamic measurement so it applies from zero to any RPM. The reaction time is nearly instantaneous (< 2uS) so there is no delay from fault to shutdown.
The comparator levels are set to the minimum acceptable encoder input voltages. The secondary advantage of the circuit is it will reject sub-standard encoders from the get-go instead of allowing them to operate and produce faulty results.
Mariss
Old 03-19-2009, 02:26 PM
MrWild is on a distinguished road
The terminals are fine with the right screwdriver. I'm curious how the drive knows how much reverse current to give in order to stop the motor. Does it sense back emf? How can it do that while the drive is pumping juice to the motor?
Old 03-19-2009, 02:28 PM
Gold Member
Paul,
Size has an effect on price. Printed circuit boards price-out by the square inch, metal by the pound, inventory stock by the cubic foot and shipping by weight. The connector is the single most expensive item in the drive; larger means even more expensive.
Mariss
Old 03-19-2009, 02:43 PM
Gold Member
MrWild,
Any error (following error, encoder fail, short-circuit, over-temperature, under-voltage, disable input, etc.) results in the motor leads being shorted together by the bottom pair of power MOSFETs. This 'shorting' (called dynamic braking) causes the motor to act as a generator and quickly dissipate kinetic energy. Motor current still passes through the current sense resistors and the current limit circuit (set by the LIMIT trimpot) regulates the current to not exceed that value. This refinement has the added benefit of controlling motor current during a hard-stop (running into a brick wall) and preventing over-current failure of the drive.
Mariss
What happened with the G380? davo727 Gecko Drives 22 04-17-2009 06:32 PM
SNEAK PEAK: CNC Fusion X3 Deluxe kit wisp Product Announcements & Manufacturer News 17 03-09-2009 11:01 PM
A sneak peek at the competition Death Adder Coding 6 07-18-2006 09:54 AM
Sneak preview of a new screen for Mach3 ynneb Screen Layouts, Post Processors & Misc 27 04-03-2006 05:04 PM
LetterCam Sneak Peak WarrenW General CAM Discussion 14 02-24-2006 02:17 PM
