Old 03-02-2009, 04:34 PM
jhowelb is an unknown quantity at this point
G203V's and blown(?) power supply
So the gremlins are testing my sanity. My system has been up and running for some time now, happily turning out my projects.
Now today when I power up there is no response from the steppers. Closer inspection shows the BOB getting it's 5 volts from the little wall wart connected to the same AC source but the lights are out on the G203V's.
My multimeter shows 1 volt dc where there should be 40. I can't buy that so I switched to AC on the multimeter and find that it is indicating 86 volts on the down stream side of the rectifier.
The only smoke is coming from my ears! Has the rectifier dumped? More importantly, what has happened to my Geckos?
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
Old 03-02-2009, 04:44 PM
Al_The_Man's Avatar
I would remove all load from the DC supply, leave the cap in place, and check the DC again.
If you get voltage on the AC side and no DC then it virtually points to the rectifiers or bridge.
BTW, 86VAC will give you 120v DC, is this what you need?
Also, a quirk of the Fluke meters is that before you get a low battery alarm, the AC voltage reads about x2 that it should.
Old 03-02-2009, 05:01 PM
Not a chance that I'm trying to put that much juice into a Gecko! There has always been about 40 vdc at the cap. That's where I'm getting 86 vac! (unless my meter has ALSO gone nuts!)
Old 03-02-2009, 05:35 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Easy enough to check the meter--stick the leads into your AC socket and see if it reads normal AC Voltage. Geckos should be fine--Worst case blown internal fuse.
CR.
Old 03-02-2009, 05:42 PM
I may have uncovered a part of the problem. A wire terminal, one of those that you crimp in place, released the positive wire at the point of connection with the cap.
After the system bleeds down I will reconnect and remeasure everything.
(GRRRR......)
(Meter reads 119 vac at input to the xformer)
Old 03-02-2009, 05:52 PM
(GRRRR......)
Sounds like you know what it feels like to handle a live cap!
You may have found entire problem. I hope so!
CR.
Old 03-02-2009, 06:01 PM
LOL, I have NO desire to experience an instantaneous discharge! (Especially into one of my digits!)
For any newbies reading, please pay attention !! A live (charged) capacitor will zap you like a lightening stroke!
Old 03-02-2009, 06:02 PM
Al_The_Man's Avatar
I found out a long time ago that the ordinary single lever hand crimper was very unreliable after experiencing many bad connections, I now use the pre-tension type, these automatically amplify the normal single leverage type and only release when the correct compression is met.
Old 03-02-2009, 06:36 PM
At about the time that I think I'm really getting the "hang" of the electronics end the gremlins throw me another curve ball. Actually, this one is a screwball!
Al, thanks to your suggestion about removing the load I found the errant terminal. Else I'd still be pulling my hair out by the handful. (Don't HAVE that much!)
The little Geckos are happy, I can see their little green eyes shining back at me. (Best investment I ever made!) The meter shows me 42 vdc at the cap but still insists that there is a presence of 86 vac!
So I've lost a day of production (I'm retired!) and sprouted several dozen gray hair while learning a hard won lesson about connectors.
All is well that ends well.
Thanks for the response, guys and a big kiss to Mariss for the G203V!
Old 03-02-2009, 06:42 PM
Glad to hear all is well! Tomorrow starts a fresh new day!
CR.
Old 03-02-2009, 11:17 PM
Al_The_Man's Avatar
Its not unusual to find that Electronic Multimeters give strange results when used on the wrong Range Setting.
On AC, your meter is looking for and AC signal, pure DC confuses it.
  #12   Ban this user!
Old 03-03-2009, 12:07 PM
acondit's Avatar
acondit is on a distinguished road
Many years ago I was playing with an electronic flash for my camera. I had something like a jewelers screwdriver and I shorted (accidentally) across the leads of the flash capacitor and it ate the shank on my screwdriver.
So yes, do not touch live caps.
Alan
http://www.alansmachineworks.com
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Fanuc Power Supply Internal Fuse Blown hrhoward Fanuc 1 01-07-2009 03:42 PM
Best breakout board for G203V's? Degrom Gecko Drives 28 07-04-2008 08:21 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
