Old 02-22-2009, 10:40 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Past problems.....
Hey everyone, i'm sure you have all seen my threads with all the issues I have had over the path months. I sent my Rev 3 to Gecko for an upgraded, they said that everything that was replaced should solve my issues.
I decided to go out today to Harbor Freight, I really looked around today and had my coupons ready.
I ended up getting a Digital multimeter, I never checked the voltage with the Analog meter. Well I did, but it really it was hard to understand it and know if it was really working.
Well, the meter I bought (4 dollars) is pretty amazing, anyway...I checked the output o my Keiling PS; it was outputting close to 60 volts!
I had no idea that the PS was doing this, maybe this was causing my problems? To many volts into the 540 and heating things.
Using the "pot" to adjust the voltage, I dropped it to about 49 volts now. Have not tested, but this is odd!!!!
-Jason
Old 02-23-2009, 07:03 PM
Anyone have any comments or thoughts on this?
-Jason
Old 02-23-2009, 10:43 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Gecko 540 doc says 50V max. Mariss usually says just what he means. Running 60V into it was probably not helping and may well have been hurting a lot.
I have seen discussion about leaving a 10-20% margin from the peak allowed voltage too. For my 80V Geckos, I don't like to run more than 70-72V in.
For a 50V rating, you might want more like 45V in to the 540.
Cheers,
BW
Old 02-24-2009, 12:54 AM
LaserImage is on a distinguished road
Actually, 48 is just fine, no need to go less. Mariss said somewhere what the absolute maximum is, I just can't find it. My guess is that if he put 60v into it and it still worked then he didn't exceed the maximum but he exceeded the rated voltage - two different numbers.
G
Old 02-24-2009, 09:06 AM
I know I exceeded the voltage. I couldn't beleive that is what I was outputting. I hope this somehow did cause problems because now maybe with the lower voltage I will be ok.
Mariss said the break point was like 65 volts I think? In any case, I'm glad I got that multimeter.
-Jason
Old 02-24-2009, 09:44 AM
Yes but, if you search you will also find a thread suggesting you not run right at the rated limit. If your mains surge at all, you can get into trouble in a hurry.
Leave a margin of 10%. It will matter almost not at all to your performance.
Cheers,
BW
Old 02-24-2009, 10:34 AM
No no, I know that. I'm just saying that for "factual" purpose, I think the break limit is 65 volts. Not that I want to run at that volts.
-Jason
Old 02-27-2009, 06:12 PM
Gold Member
Mariss Freimanis is on a distinguished road
The G540 breakdown voltage is 67 to 69VDC. Do that and you need a new fuse.
Mariss
Need Help!- Cannot go past 60ipm! greenene K2CNC 5 11-07-2008 08:55 PM
Need Help!- Cannot go past 50 ipm! greenene Controller & Computer Solutions 9 11-05-2008 11:26 PM
Need Help!- Cannot go past 50 ipm! greenene Controller & Computer Solutions 1 11-04-2008 03:37 PM
CncZone - Blast from the past Switcher CNCzone Club House 1 10-08-2008 05:17 PM
Some of my past cnc laser work jeffrm20 Laser Engraving & Cutting Machines 0 09-21-2006 09:59 PM
