Old 02-22-2009, 06:27 PM
sse4 is on a distinguished road
G540 Rev.1 has problem
Hi there.
I have a G540 rev. 1 control, that developed a strange problem. After some difficulties I got it to set up the right way, but the Y drive stepper made noises like loosing steps. Run some short Eagle PCB nc files to test the mill, but the noise in drive Y just got stronger, and getting harder to homing. Switched X and Y cables, run the same test, then the X was bad, Y was running fine. Then I made "A" drive replacing all the Y functions, it was going fine too. Ok I thought, will carefully took it apart, and exchange the "A" 250 drive with the "Y" one, but Y drive still had the problem, So I guess there should be a problem somewhere in the G540's motherboard. Now the question is, can I do some more checking, measure, or maybe any "repairs" to solve this problem. I live in Eastern Europe, and the distance could create some difficulties, bat if there is no other way then I have no choice will send it back to repair.
The 250's are rev.5, those reworked ones. ( Sorry for the long post.)
>Jim.
Old 02-23-2009, 02:07 PM
LaserImage is on a distinguished road
If I'm not mistaken the earlier 540's had different configuration or pinouts on the A, XY and Z were the same, but A was different. I would contact Gecko directly and they can tell you exactly what is what.
Gary
Old 02-23-2009, 03:21 PM
Yes Gary, you are right, the config for the rev1 is totally different from rev3. For example, the E-stop switch is normally closed type, needs +5volts from PC, and some more, but I was able to set it up correctly, only problem was, as I mentioned with the "Y" drive. First I thought my Y travel has some serious problems, but when I changed to drive "A" was going just fine.
Thanks for your concern, but I'm afraid I need to contact the Gecko people.
>Jim.
Here is rev1 LPT pinout:
http://cnczone.com/forums/attachment...1&d=1235423818
Name:	540 rev1 LPT pinout.jpg‎
Old 02-23-2009, 08:14 PM
rowbare is on a distinguished road
If you do need to send it in, you can get the motherboard upgraded to the Rev 4 motherboard so all of the drives will be identical.
http://www.cnczone.com/forums/showpo...27&postcount=5
Old 02-24-2009, 08:08 AM
rowbare,
Thanks for the info, I somehow missed Mariss's post, this is great news. I have 2 G540 units, got one for my friends, they are both identical rev1. He newer hooked his up yet, but I'll will send both G540's back for upgrade.
I'm a bit confused with Geckodrive Inc. mailing address. Want to confirm, that I'll send it to the right place, then I find out there are more companies under the same name in California with different addresses. I have this address on the parcel with the drives:
"GECKODRIVE INC. 14662 Franklin Ave. Suite E Tustin, CA 92780"
would that be the right place to ship it back for the upgrade? Someone could confirm this, thank so much for your efforts.
>Jim.
Old 02-24-2009, 08:35 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Jim!
That is the correct address.
From the Gecko Website:
http://geckodrive.com/upload/STEPPER%20RETURN.pdf
CR.
Old 02-25-2009, 07:48 AM
Thanks.... C.R.
Now at least I know did sent it to the right place. Just mailed both of them today, I think it will take at least 2 weeks, till it gets there, priority and registered, but sometime I feel like living on an other planet. But no big deal, as long as it gets the upgrade, or fix.
Regards:
>Jim.
G540 Spindle speed output voltage problem georgef8 Gecko Drives 5 09-22-2009 10:18 AM
g540 Scooby Doo Gecko Drives 62 05-17-2009 01:44 PM
can you... BOB to G540? Fixittt Gecko Drives 7 01-28-2009 06:37 AM
Need Help!- G540 problem, steppers not moving CS900 Gecko Drives 36 11-13-2008 10:38 AM
G540 fault problem jemmyell Gecko Drives 12 10-21-2008 05:50 PM
